Https://www.youtube.com/watch?v=nalSGHbmJC4
https://www.youtube.com/watch?v=Pje2hPO9K3M
https://www.youtube.com/watch?v=LYP3ZalF5NY
Have a couple manuals, you may find one is better than the other to search through.
https://www.manualslib.com/manual/1064818/Kubota-Zd21n-Ec.html
https://www.manualslib.com/products/Kubota-Zd21-Ec-4086446.html
https://www.kubota.com.au/wp-content/uploads/2015/09/agopszd22101.pdf
ZD21N-EC,ZD21-EC,ZD28-EC - Kubotabooks.com
SOURCE: Where can I find a picture of the idler pulley
go to partstree.com,put your model# in ,then click deck assy. hope this helps.please rate this thank's
SOURCE: I have a Craftsman 20 HP 42
Did you obtain the correct replacement belt AND pulley. Double check your part numbers against the parts list for your machine. If you verify that they are correct, double check the belt routing, make sure it didn't get on the wrong side of a belt guide and is in the correct configuration. Look at your idler pulley and make sure the release spring is doing its job pulling it back from the applied position. Make sure that the arm for the pulley moves freely where it is bolted to the deck, it could be bound up with rust or debris. You should have a lot of slack in the belt when it is in the released position. If it does not then either it is the wrong part or improper installation
SOURCE: The mower deck drive belt slipped off the idler
Get the model number off the tractor, go to:
www.murray.com
enter the model number and you will find a manual with pictures of how to route the belts along with a lot of other good information
