SOURCE: Wurlitzer One-More-Time CD Jukebox can you get an adaptor to plug
Yes, you can buy an iPod docking bay and background music adaptor and play your iPod throught the jukebox. If a CD is played it over rides the iPod music until it has finished playing. It is called and iPod docking bay kit.
Dave F.
SOURCE: Loaded game = loud buzzing
After removing the casing, all that need to be done was loosen (yes, loosen) a screw on the inner frame about a quarter turn. This allowed a little movement to the frame and stopped the buzzing.
SOURCE: missing CD player of Wurlitzer CD Jukebox model New York,NY 1993
All of the one more time jukeboxes used the Phillips CD player, they started with the CDM3 then the CDM4 and CDM12 etc.
Around 1993 it would have been the CDM3/4.
You need to identify which Decoder it is using in the jukebox or you need a kit that replaces the CD player and Decoder.
Regards
Alan Hood
ami-man
UK
SOURCE: I have a Rowe AMI 100CD jukebox. Its making a loud
Hello camillemario,
The problem sounds as if there is a fault on the amplifier.
Pull the 110 volt plug from the power supply that feeds the amplifier.
If the amp is at fault and you are in the USA I would contact Bruce Wentworth for a test/repair to your amplifier.
Bruce Wentworth A&B Jukebox Repair 56 Old County Rd. Plaistow NH 03865. A&B Jukebox Repair specializes in the repair of Rowe circuit boards in Rowe ...
www.abjukeboxrepair.com
Regards
Alan Hood
ami-man
UK
SOURCE: how do you connect an ipod to a wurlitzer cd
If it uses a K99 amp you can buy an iPod docking bay as a kit to fit to the juke. If it is a Compact I84 amp you can't.
