I unplugged my boxErector model c-300 scairl# CE000514 an moved it pluged back in know it wont start reading a fault
3 Suggested Answers
6ya staff
SOURCE:
dfox230
  • 4 Answers
SOURCE: no power
Have you checked the outlet for power if so open up set to see if fuse came out during moving it if fuse checks ok look for cold solder joints in power supply dfox230@yahoo.com
Posted on Jan 24, 2009
richie46
  • 12962 Answers
SOURCE: when tv is unpluged and pluged back in it wont power on and no lights blinck
Sure the plug is getting power from wall outlet? If power is there you might want to check out the power supply board first for issues.
Posted on Oct 13, 2015
When tv is unpluged and pluged back in it wont power on and no lights blinck
Oct 13, 2015 | Televison & Video
Treadmill will not come on
Watch this videos:
You must check the fuses+breaker inside from machine +breaker from house, of course check power cord if there are some loose cable, or another loose cable inside from the machine, or broken cable. Tight any cable inside.!
http://www.youtube.com/watch?v=N6Yg5S0WML8&NR=1
http://www.youtube.com/watch?v=bF3OyQ3HwfU&feature=related
Oct 29, 2011 | Exercise & Fitness
How to ajust fan belt on peugeot 406
your abs fault will be the right rear wheel speed sensor, it wont need replacing you just neet to remove the brake caliper and caliper frame, remove brake disc so you can get to the allen key bolt that holds the sensor in. remove the sensor and clean up where it sits and re-fit. as for the speedo fault i think the speedo drive is located on top of the diff. you may want to try removing the clocks, unpluging them and pluging them back in again
if this helps let me know
cheers
mike
Feb 19, 2011 | 2005 Peugeot 405
Vw bora
hi their how are you ? are you local to east sussex ?i work out of their it hard to say why your airbag light i on most of the time it the wireing undre the front seats get move or comes unpluged but you wont be able to turn the light out without a computer if its loged a fault now as it thinks that there is something wrong it would have to be rest sorry. the abs light comeing on when you start the car means their is a fault with the abs motor or a wheel sensor but again with out pluging in to the car its hard to tell you what the problem might be the reverse light is most of the time ie a bulb switch in the gear box or a fuse . i hope that helps you let me know what happens thanks
Jun 26, 2009 | Cars & Trucks
Hard start, wont idle 2000 kaw 300 r
if your pilot jet is pluged it will not idle. the pilot jet controls fuel from o-1/8 throttle setting only
Mar 16, 2009 | 2002 kawasaki KLX 300 R
2003 lexus is300 check engine and traction light blinking
I had the same problem with mine, mechanic said it was a result of the O2 sensor (s) needing replaced. He replaced them and problem was solved.
Mar 09, 2009 | 2003 Lexus IS 300
Clicking noise in the back of tv and wont come on no standby ligh
The TV is in protection mode because of a fault with moving it and then coming on briefly I would suspect that the fault is a dry joint ( a solder joint which has fractured) finding it can be time consuming but it is most likely to be around the caps in the line output stage which need resoldering.
SUPER8
Dec 01, 2008 | LG 30FZ1DC 30" TV
Freezer
Unplug it and manually defrost it. making sure that the inside of freezer has reached room temprature thenplug it back in and see if that helps.
Aug 03, 2008 | Haier Freezers
ASKO 1595
yes have you tried what i suggested yet
Mar 29, 2008 | Asko D1776 Stainless Steel Built-in...
Televison & Video Logo
Top Televison & Video Experts
Marvin
Marvin
