The systolic pressure was determined but afterwards the cuff pressure fell below 20
mmHg. This situation can occur if the tube becomes unplugged after the systolic blood
pressure has been measured. Check the tube connections and repeat the measurement.
Further possible cause: No pulse could be detected
SOURCE: blood pressure monitor problem
The two numbers that measure your blood pressure are written like a fraction: one number on top and one on the bottom. The top number in a blood pressure reading refers to the systolic pressure. It measures the pressure inside your blood vessels at the moment your heart beats. The bottom number represents your diastolic pressure. It measures the pressure in your blood vessels when your heart is resting between heartbeats. A good blood pressure for most people will be under 120/80, as most people with blood pressure problems have high blood pressure. However, extreme low blood pressure can also be a serious health concern.
SOURCE: mabis 04-206 blood pressure monitor getting err
what kind of error you getting from bp monitor please be clear and write in detail if not please feel free to call me +91-9884462250 Rehman
SOURCE: mabis 04-206-001 blood pressure monitor getting
need to read instructions or mess with it to set it up
SOURCE: I NEED THE MANUAL OR INSTRUCTIONS FOR THE CVS BLOOD PRESSURE
Press Set Time/.Date button and hold down for several seconds. When you let go number - year - will start flashing. Use MEMORY button slowly to correct year. Push Set Time/Date button to set year. Next number will be month - same process. Then date - same process. Then time beginning at midnight using 12 hour clock - same process.
SOURCE: HD 1000S Blood pressure monitor will not display blood pressure after inflating code ERR 1
tighten the cuff more around the arm or if you have a small arm pull your sleeve down then put cuff on and try it that way see if it helps
