Kenmore 30172 / 30174 / 30179 Gas Single Oven Logo
Bruno Châteauvert Posted on Sep 14, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
F1 message on Kenmore oven
After using my kenmore oven model # C96863183-2 at hi temperature I got an F1 message that is still on the screen. The oven, the clock and the timer don't work. I can still use the the cooktop elements.
Anonymous
Level 3:
  • Master 15,935 Answers
  • Posted on Sep 26, 2010
Anonymous
Master
Level 3:
Answers
15935
Questions
19
Helped
5034332
Points
35540
Here is some wisdom for understanding F1 fault codes.
In some models, there are subcodes that make diagnosis even easier.
Here's a simple explanation of what's going on and how to troubleshoot:
The F1 code indicates that:
a. The electronic range control (ERC) is sensing heat in the oven when in a time-of-day (i.e., not cooking) mode.
b. The ERC is receiving information to run multiple heat functions simultaneously.
Although different components (depending upon the model) could generate the code, simple and straightforward testing using your ohm meter is all you gotta do to test for it.
1. Check the oven temperature sensor. The oven sensor has to be within spec or it will cause the F1 code.
As an example of being out-of-spec, the ERC will generate an F1 fault code when the sensor shows 1650 ohms during a time-of-day mode.
This is equivalent to 350°F in the oven.
The resistance isn't high enough to generate an F2 code (runaway temp) or an F3 or F4 code (shorted/open sensor circuit).
The ERC monitors the sensor circuit after a heat cycle and expects the resistance to drop back to 1050-1100 ohms.
The fault code is generated when this doesn't happen. Checking the sensor circuit means also checking the harness,
harness connections and the sensor itself.
2. If the oven sensor circuit checks okay, then turn your inquisitive eyeballs to the touchpad.
If the range has a separate touchpad/keyboard, the keypad may have moisture that is shorting several circuits simultaneously.
If the F1 code is given immediately (instead of during or after a heat cycle),
remove the ribbon connector from the touchpad to the ERC after clearing the F1 code. If the F1 code does not return in five minutes,
then cast a suspicious gaze upon the touchpad/keyboard. Shorts may be caused by using an ammonia-based glass cleaner.
The touchpad surface will absorb ammonia-based cleaners that are sprayed directly on the glass surface. When heat is applied,
the surface material can break down causing shorts.
If you're gonna use ammonia-based cleaners on your control panel, then you should spray it on the rag and then wipe the touchpanel
-don't spray directly onto the surface of the touchpad.
3. On Amana ranges with a rotary temperature dial, be sure that the knob is in the OFF position when performing tests.
4. If these tests all check good, then replace the ERC.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
2answers
Oven not working - Kenmore C970-615021.
you're correct about the control board being the issue. I would first get in-home assistance from home depot to help get the proper part number before making your order. And then you can order through kenmore.
Thank you.
7helpful
Can you tell me what an F1 error Message means - 30 minutes into baking, I got beeping and an F1 error message. Canceling did not turn the oven off and the only thing I could do is turn it off at the...
"F1" code clearly indicates that main control board has failed. The possible fix for this kind of problem is you have to replace the faulty circuit board. This is the only solution and you cant repair anything else in this unit when F1 flashes.
Thank you !!
1helpful
My oven when turned on goes to F1 and the heat is like broil...only the top burner comes on????
Hello,Please use the chart to determine which stove you have. You will have to look at the model number. The first 3 numbers will be the series on the chart. In most cases an F1 error would require replacement of the electronic control. This part is commonly refered to as an EOC or ERC. However this type of repair is usually reserved for repair specialists.
KENMORE Range/Stove/Oven Fault Codes – 362 Series (General Electric)
F1 = Stuck Touch Pad Key - Replace Electronic Range Control (ERC).
KENMORE - 911 Series (General Electric/Roper)
F0-F1-FF = Failed transistor in Electronic Range Control (ERC).
KENMORE Range/Stove/Oven Fault Codes- 665 Series (Whirlpool)
F1-E0 EPROM Error - Electronic Range Control (ERC).
F1-E1 EPROM Error - Electronic Range Control (ERC).
F1-E2 U/L ERC Errors - Electronic Range Control (ERC).
F1-E3 Fuel Type Fail
Kill power 30 seconds-Cancel-Start/Enter-5 seconds-Should see “E” for electric-
“9” for gas-If code changes again-replace Electronic Range Control (ERC).
KENMORE - 790 Series Electronic Oven Control (Frigidaire)
F1 = Shorted Touch Pad = Electronic Range Control (EOC) Internal check sum error.
Runaway Temp = Replace Electronic Oven Control (EOC).
Kill power 30 seconds - if error returns - replace Electronic Oven Control (EOC).
Thanks
2answers
Moved into this house. Has no manual on Kenmore glass top stove, on how to use self cleaning oven. Looking for manual or directions on how to use it. Only have model # 790.96011400 and serial # VF50635079
Before you go working too hard to get you oven to go into the self clean mode....check out this tip...
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! " - amymrocks
Apr 13, 2010 • Ovens
E1-F1 error on Kenmore Range
A persistant F1 error code usually means that the oven has exceeded the safe maximum operating temperature for the oven.
This is usually due to a faulty oven thermostat unit.
If the error code reappears after using the oven you should get the thermostat replaced.
1helpful
E3 F1 code on key pad kenmore specail edition
All F3-E Codes - Oven Temperature Sensor (RTD) or Warming Drawer Defect - Replace oven temperature sensor (RTD).
6helpful
My kenmore oven is beeping and will not stop. the display shows F-1.
Please use the chart to determine which stove you have. You will have to look at the model number. The first 3 numbers will be the series on the chart. In most cases an F1 error would require replacment of the electronic control. This part is commonly refered to as an EOC or ERC. However this type of repair is usually reserved for repair specialists.
F1 = Shorted Touch Pad = Electronic Range Control (EOC) Internal checksum error.
Dec 16, 2008 • Ovens
3helpful
4answers
My kenmore electronic stove is having a beep with code F1 on the
F1 error message on kenmore gas range
The F1 usually means a problem with the touchpanel. It is also related to the F7 problem. I have developed a fix which may solve you problem. Please go to the following link for my fix.
http://www.fixya.com/howto/h155060-dreaded_f7_error
I have shared my fix with over two thousand unhappy GE customers. Most report success. Please let me know if this works for you too. I am making a statistical study of this problem.
Regards,
Powerman
[email protected]
Kenmore Error F1
The F1 usually means a problem with the keypad, not a sensor. You might want to try my fix for a similar problem with an F7 error message.
You can find my fix on this web site at:
I have shared my fix with over 1500 folks and most report success. I hope that it works for you too. Please let me know at:
[email protected]
Also, what is your model number, how old is your oven and where are you located? I am making a statistical study of this problem.
Regards,
Powerman
Top Kenmore Ovens Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
