Question about Taylor Hardware & Accessories
My partner was looking at the current conditions settings screen earlier on my taylor c723 and pressed a button, now the screen says communications failure and none of the buttons work.
    Master:
  • 723 Answers
Start by unplugging, wait a minute, reconnect. Hopefully, that resets things and you can start over.
Posted on Oct 04, 2019
SOURCE:
SOURCE: Top Buttons on Keyboard not working
Go to your Start menu, Control Panel, then look for Keyboard.  Sometime keyboard is listed by itself, other times it is under another device name.  Click open keyboard, then click on the BUTTONS tab.  You will see 5 "buttons or selection options:  Calculator, E-Mail, Help, Search,Connect.  Mine does not open the Club Q button ...that's what I am searching for at this time.
Skip the calculator one (once the others enable, this one fixes itself for some reason. I went to the e-mail button first.  Double click it. Under choose a button capability: scroll down to the "Simple local file with label".  Then go to the bottom "ADRRESS" area, delete what is there and put in your favorite web based e-amail addree login address.  For yahoo.com it would be:  Http://login.yahoo.com ...yahoo will switch you to their secure server don't worry.  Do the same for any of te buttons you wish to change.
If the buttons do not show up at all, then you will need to upgrade your driver.  HP has an upgrade for its multimedia keyboard, I am sure you can google yours and find it, even if Windows cannot do so.
You have to have the Calcultor chosen on your Windows setup for it to work, but it just pops up after you update the other buttons.  If it doesn't. Its address on an XP os is:  something like: c (whatver your hardrive is located)://windows/system32/calc.exe ... thing is it can be different for different systems.
Now to figure out how to use that 6th button, the Q Club one?
Good luck.
Posted on Oct 18, 2007
Shinigami
  • 58 Answers
SOURCE: None of my buttons work except the ON button
Sounds like a possible short to me, But I don't have experience with that cause I have yet to test my calc with water if you know what I mean... The one thing that I can suggest is trying to connect with another persons calc and try the "send OS" command to see if that will reset your calc to a working state. Sorry to hear about the damage though.
-Saik0Shinigami
Posted on Feb 07, 2008
  • 1684 Answers
SOURCE: HP 7590 office jet pro scanner does not communicate
The scanner function is not available when you are connected wireless, you must be connected via USB to your PC for the scanner to function correctly.
Buddy
Corporate Computer
Over 21 years of PC and printer support/repair
Posted on Jun 18, 2009
SOURCE: My remote for my Panasonic DMR-ES45V will not work
Press 1 and ENTER together. Hold for 10 seconds.
Should splve problem
Posted on Jul 28, 2009
SOURCE: My zune middle button won't work
well i had the same problem for about 3 months...i tried doing research and found a website...http://www.rapidrepair.com/guides/zune/zuneassemblyguide.htm...i took my zune apart and then followed the steps only till step 5..then i let it sit out like that for about and hour, then i put it all back together and my buttons work..there is also video on youtube for problems like this, simply go to youtube and type in <Take apart zune to reset (doesn't work)>
Posted on Aug 16, 2009
How do I set the time on a KADIO KD-3806 digital clock
Earlier FIXYA question:
sachin_arane
ALL PARAMETERS CAN BE ADJUSTED BY USING KEYS
GIVEN BACKSIDE...KEYS ARE
MODE (LONG PRESS-4 SEC) TO ENTER INTO SETTINGS;
UP/DOWN TO CHANGE THE PARAMETERS; \
*C/*F KEY TO TOGGLE BETWEEN TO TEMPERATURE FORMAT;
SNOOZE BUTTON TO SET SNOOZE IN ALARM-MULTIPLE SNOOZE CAN BE SET;
RESET KEY CAN BE USED TO RESET CLOCK TO DEFAULT;
DAY COUNTDOWN , AND TIME COUNTDOWN CAN BE ADJUSTED;
DETAILED INFORMATION TO SET THE CLOCK
INSERT CELLS;-SCREEN SHOWS DEFAULT VALUES-INITIAL MUSIC WILL RING;
LONG PRESS MODE BUTTON-KEEP IT PRESSED UNTIL 12 STARTS BLINKING;
USE UP /DOWN BUTTON TO ADJUST HOURS...
THEN SIMPLY PRESS MODE AGAIN, NOW MINUTES 00 IS DEFAULT WILL START BLINKING;
USE UP/DOWN BUTTON TO ADJUST MINUTES;
AGAIN PRESS MODE, SCREEN WILL SHOW YEAR 2002 DEFAULT BLINKING, USE UP/DOWN KEY TO ADJUST YEAR;
AGAIN PRESS MODE, SCREEN WILL SHOW MONTH BLINKING, USE UP/DOWN KEY TO ADJUST CURRENT MONTH;
AGAIN PRESS MODE, SCREEN WILL SHOW DATE BLINKING, USE UP/DOWN KEY TO ADJUST YEAR;
AGAIN PRESS MODE, SCREEN WILL SHOW 12:00 BLINKING WITH ALARM SIGN (FOR ALARM SET);USE UP/DOWN KEYS TO SET ALARM, FIRST HOURS AND THEN MINUTES FOR ALARM; THEN ON PRESSING YOU CAN SELECT SNOOZE MINUTES;
AFTER SNOOZE ON PRESSING MODE AGAIN YOU CAN SELECT DAY COUNTDOWN TO SELECT 999 DAYS COUNTDOWN FROM CURRENT DATE;
when watch displays time and everything .....
each and every buttons has some function;(shortcuts)
press down to toggle between 12hr/24hr format;
press up to enter contdown timer;
press snooze to set snooze in alarm;
press c/f to toggle between two temperature formats;
press mode to toggle between alarm time and current time
Mar 18, 2018 | Car Audio & Video
Brush Cleaning did not clear the (L / R) HPR> 45F (7C) AFTER 1 HR fault on my Taylor Model C723 soft serve ice cream freezer.
Certain conditions must be met. The machine needs to be empty. The freezer door must be off the machine. The power switch must be off. Once the machine is off, a 5 minute countdown will show. It will also show 4 temperature readings. All 4 of them must be above 60 degrees F. before the countdown will start. Once the counter reaches zero, the Brush Clean Cycle will be reset along with any temperature vs. time error codes. If at any time, one of the temp readings drop below 60 degrees F. before the end of the 5 minute countdown, the countdown will reset to 5 minutes and the machine will not reset. Generally, the freezing cylinders take longer to come to temperature. Even when you run warm water through it first, there is sometimes enough residual cold to bring the temperature back below 60. A successful Brush clean Cycle will display "Power Switch Off---Unit Cleaned" and the 2 digit green display under the main display will reset to 00. if this happens and you turn the machine back on and you are hit with the same message then you may have an issue with one of your boards.
Aug 02, 2017 | Taylor Ice Cream Makers
Compressor hpco
Compressor hpco or (High Pressure Cut Out) means the high side pressure has went over the limit the machine has been set too. The safety is there to protect the compressor. If the machine is water cooled, the water flow has most likely been interrupted. So often the machine was moved for cleaning and the wheel is on the water hose. If the machine is air cooled, Either 1. the fan has stopped, 2. the condensers are dirty or 3. It's just too hot where you are trying to run the machine.
Soft Serve Parts C723
May 06, 2017 | Taylor Ice Cream Makers
We have just got a second hand Taylor c723 machine and it keeps saying freezer locked. Any ideas
Empty the machine, clean it out. Remove the freezer door assembly, shut the machine off. it should display a 5 minute timer and 4 temp readings. All 4 of the temp readings need to be above 60 degrees F. for the counter to start. Once it reaches zero, the machine will reset and you should be good to go. If successful the machine will display "Power Switch Off---Unit Cleaned". if at any point during the 5 minute countdown, one of the temp readings drops below 60, the countdown will reset to 5 minutes and the machine will stay freezer locked.
www.softserveparts.com
Apr 13, 2017 | Taylor Ice Cream Makers
How do I reset the clock on a Taylor 5846-9 kitchen timer?
Press the Mode button until you are on the clock.
Then press and hold the Start/Stop button for 3 seconds.
There should be a beep and the digits will begin to flash.
Press the Min button to increase the Hours and press the Sec button to increase the minutes.
When you have the time set, press the Start/Stop button to finalize the setting.
Nov 03, 2013 | Taylor Hardware & Accessories
How do I reprogram the phone to ring when a new call comes in, default to a certain line, and show caller id when a call comes in.
The answer to the Caller ID question:
Depend on the type of system that the phone is connected to. Late model Partner ACS equipment will display Caller ID info between the first and second rings, provided that the telephone line is plugged into a module that supports Caller ID.
The answers for the other 2 questions are taken directly out of the Partner ACS Programming Guide which is available for free download at Avaya's website.
Ther answer to the incoming call line ringing question:
Again, depends on the system. For the Partner ACS:
1) Press FEATURE 00 at extension 10 or 11.
2) Enter the number of the extension to be programmed for Line Ringing.
The green lights next to the line or pool buttons show the current Line Ringing settings for all
lines or pools assigned to the extension. (If a line or pool is not assigned to a button, the green
light next to that button is off.) The following ringing options can be shown by the green light
next to the line or pool button:
? Immediate Ring - on steady
? Delayed Ring - flashes slowly
? No Ring - flutters quickly
3) Press the line or pool button until the button light shows the correct setting (the setting for the
currently selected line or pool also appears on the display).
4) Continue programming, or exit programming mode.
Line selection:
For incoming calls, the line selection (hunt sequence) is set by the local service provider). For outgoing calls....again....it depends on the system. For the Partner ACS:
1) Press FEAURE 00, SYSTEM PROG, SYSTEM PROG, CENTRAL PROG at extension 10 or 11.
2) Enter the number of the extension to be programmed for Automatic Line Selection.
3) Press **.
4) Press the line, pool, or INTERCOM buttons in the desired order. The valid entries for Automatic
Line Selection
depend upon the type of extension:
? Key Extension: Outside system lines, Left Intercom (the factory setting)
? Pooled Extension: Pool 880 button 1, button 2, Left Intercom, Right Intercom (the factory
setting), Pools 881-883, individual lines
For each button pressed, a display similar to the following appears:
5) To exit Automatic Line Selection, press **.
6) Press CENTRAL PROG and enter a new extension number, or exit programming mode.
Changing line ringing and line selection are tasks that are normally reserved for the Administrator of the telephone system.
Jan 06, 2011 | Lucent 18D Corded Phone
How do i reset clock for the taylor clock timer 5851-21?
my Taylor 5851-21 has Hour Min Then under thatt Timer/Reset abd Start/Stop. How do I set the time. I know how to work the timer and reset the timer, but I need to set the clock. But it does not have a clock button label as you describe above.
Nov 20, 2009 | Taylor Hardware & Accessories
How do i get my lucent partner 18d to show caller id name & number
2 line caller id is offered on newer versions of software. On earlier versions a call id name button is used to toggle between the clid name and number.
To program a button on your set press feature 00, press a button you wish to program as clid name,
and press feature 16, press feature 00 to exit programming. Press the button to toggle from clid number to clid name
Nov 03, 2009 | Lucent PARTNER18 Corded Phone
Cect phone a8+ freezing
If you are talking about the touch screen not being responsive at all under normal conditions, read on.
First try calibrating it. There are 2 ways to get to the calibration screen. Please use the stylus to calibrate!
The fastest way is to be on the slide-lock screen & hold the side volume button in the Up position until
"Press volume down key to check" comes up onscreen. This may or may not work on all firmware versions
on the current i9, but works on most. Make sure to hold the button firmly in the Up position. You will first
see the normal volume speaker icon show onscreen and the volume rise, but just keep holding it Up, and
eventually you should see the pop-up box noted earlier. The moment you see that pop up onscreen,
immediately press the side volume button in the down position. A white calibration screen should now
show & you can calibrate the touch screen using the stylus. Try to tap as close to the center of the little
pulsating icons as possible, as this will more accurately calibrate your touch screen. If the calibration
screen didn't come up using that method, then you can get to it from the Main menu screen.
Select "Settings", then select "Pen calibration", & follow the previous instruction.
Apr 09, 2009 | Dual Electronics CECT P168 Cellular Phone
Talk about frequency change
To change channel & code press talk and monitor while turning radio on. Radio will speak current channel. Release both talk and monitor. Press talk to change to next channel or press monitor to keep current channel. Press monitor when desired channel is selected, radio will speak current code. Press talk to change to next code or press monitor to keep current code. Press talk to change code as desired then press monitor when done. Will speak channel and code selected. Set all units in same manner to communicate.
Oct 15, 2008 | Motorola Talkabout T5800 (22 Channels)...
Hardware & Accessories Logo
35 people viewed this question
Top Taylor Hardware & Accessories Experts
Gene Haynes
Thomas F. Schneider
Are you a Taylor Hardware and Accessory Expert? Answer questions, earn points and help others
