SOURCE: I have an old Columbia Garden tractor is this a MTD
go to partstree.com put your make and model# in and click the year you need from the engine window it should get you close to what you need .hope this helps
SOURCE: Can't get bolts loose on mower blades
The bolts that hold the blade need to be turned clockwise.
The bolts holding on the deck need to be turned counter clockwise
SOURCE: Does anyone know of a solid rubber tire for garden tractor?
IF YOUR TIRES ARE GOING FLAT FIND A PRODUCT CALLED SLIME
IT WILL PLUG A HOLE UP TO 1/4 IN
SOURCE: is it hard on diesel garden tractors run for short
Short runs are not hard on the unit. As long as there is oil pressure and the battery stays charged your not going to hurt it at all. Kubota diesels are very reliable.
Kelly
