I haven't used my Panasonic DVD player for a while. Today, when I turn it on, none of the buttons work except the Power button and the Channel Select. I wanted to know how to fix it?
Hi Mohammad Hooshmand, indicates model of the Panasonic DVD you are commenting on, in order to find the best possible solution
I wait your answer
Greetings Franco Dosil
Hola Mohammad hooshmand, indica modelo del DVD Panasonic del que estas comentando, para poder encontrar la mejor soluci?n posible
Espero tu respuesta
Saludos Franco Dosil
SOURCE: volume/ channel/ remote not working
I just used the following instructions from this site on my 'totally dead' Ilo remote and it worked like a charm! I did step 2 twice on each key and put the batteries back in and it worked great! Hope this helps you too. "Dead" Remotes Can Be Saved How to Re-Start Your "Dead" Remote Control This only takes about a minute and will restart 1 in 3 "Dead" Original Remote Controls. Good Luck! Step 1- Pull the batteries out of the remote and leave them out until Step 4. Step 2- Press and release each and every button one at a time on the remote control until every button has been pressed and released at least once! Step 3- If your remote has slide switches, you must move the switch to each position then repeat the button pushing in Step 2. (When you're done, be sure to put the slide switch in the correct position to operate the unit the remote came with!) Step 4- Put the batteries back into the remote, being very careful to install them correctly. New batteries should be used if you're not sure about the old ones. Step 5- Try the remote. If it works, Great! If not, it's time to call 1-800-Remotes or use this website to order a new remote.
SOURCE: DVD Player not working
I have the same problem this is the 2nd one i have bought and this is the only one i have gotten a problems with when ever i find something i'll let you know
SOURCE: dvd stuck in player
Had the same problem. After a couple of times of removing the DVD player and manuelly removing the DVD I called for a RMA and they fixed it, but they say the problem was that I had another DVD in the player. ???
SOURCE: Panasonic TH-50PX60U no buttons working
The software in the cpu of this set is damaged you must reload it to fix the problem..
SOURCE: Romote stopped working.
You can buy a replacement remote from one of the websites below:
Replacement Remotes
Toshiba for CT-90087 CT-90086 CT-9792 CT-9793 TV Remote - eBay .
Remote For Toshiba TV CT-9725 CT-9726 CT-9952 CT-9946 - eBay
Toshiba Remote Control New OEM Replacement
