Hello Wallace Honeycutt, so you say, you would have the LCD backlight system wrong, one or more
For a correct repair, you must replace all the LEDs
Find a specialized technical service
Regards Franco Dosil
Hola Wallace Honeycutt, por lo que comentas, tendrias mal el sistema de iluminacion trasera del panel LCD, uno o mas
Para una correcta reparacion, debes reemplazar la totalidad de los LEDs
Busca un servicio tecnico especializado
Saludos Franco Dosil
SOURCE: have sound and no picture
You've got a bad solder conetion,or broken foil line,s on the pcb (printed circuit board).Narrow it down by pressing in different places,or use plastic or rubber tip.If not,then you got a shorted load on this fuse and diode.do you have a schematic,whats at the end's of this circuit.D represents a
SOURCE: toshiba 50"rear projection hometheater picture shut off on/off light flashing
take the back off and change the fuse
SOURCE: toshiba hometheater 50" rearprojection
http://www.casiasfamily.com/repairlog/tp50h15.html
see the link.
the problem are the convergence amps. Its a common problem for this model. Google the model # and you'll see several postings about the blinking light.
SOURCE: toshiba projection tv 50 inch
I have TOSHIBA PROJECTION TV MODEL TZ50V51. While it was on all of a sudden it wnet blank. When you power, the red light lits and starts blikning with nothing coming on. Help please
I have a seven year Plasma TV HP PL5060. When I turn on the TV, I have sound but no picture, the screen display (power on) is a snowy blue screen and vertical pink stripe. What is causing this problem and how can I fix it cheap. I can afford a TV repair man at this time, because I am laid off from work. Thanks.
