Question about Homelite Garden
I have a homelite super 2 chainsaw that does not have a UT model number. It just says Super 2 under model. No bolt hole to install a hand guard. Is this one of a kind model.
SOURCE:
SOURCE: chainsaw carburetion
Had a similar sounding problem with my stihl MS 250. After two years of heavy and frequent use (with minimal maintenance) it ran perfectly but after three years of little use with no maintenance it began to die if the revs were allowed to drop, ie it wouldn't idle. I hadn't been draining the tank when not in use so assumed a carb gunk problem. Can also be caused by an oily mix or old fuel.
Today I removed the old fuel and fuel filter and sprayed the tank and up the fuel line with carb cleaner. Then I removed the spark plug and filled the chamber with carb cleaner (use a straw to direct), I removed the air filter and sprayed carb cleaner in here too. I gently pulled the starter cord a few times to spread the carb cleaner. I left it for 1/2 hour while I had lunch.
I then rinsed out the fuel tank with fresh fuel, renewed the air filter, spark plug, fuel filter and fuel. I checked the H and L screws were in the right place (they were), before pulling on the starter a few times to prime / flood the chamber. I then removed the spark plug for 5 mins and had a cup of tea while the flooded chamber resolved / evaporated, then fired her up. It worked well all afternoon.
No need for any tricky or delicate stuff if you give this a go first is my advice. Cost only of spark plug, air and fuel filters, fresh 2" mix and a can of carb cleaner. Took less than an hour excluding interruptions. Saved a potentially expensive trip to the shop where I'd have been billed for these parts as a routine matter.
Posted on Jan 02, 2009
  • 819 Answers
SOURCE: my homelite super 2 chainsaw keeps flooding. it
Needle valve in carb. maybe hung open. Or diaphragm may be bad. You will need to remove carb. and clean and replace all worn parts. Go to homelite.com to find manual for the saw.
Posted on Apr 16, 2009
dontbother10
  • 2220 Answers
SOURCE: Need owner or service or both manuals for Homelite
I haven't found a location of the operator's manuals but the numbers you provided made the IPL (exploded parts list) easy. Thank You. Go here:
Homelite/Ryobi.com
https://www.gardnerinc.com/recons/disclaimer-lg.php - Agree; In the "Model Name/Number" type in "UT-10654" and you are there.
Atta boy/girl
Lou
Posted on Sep 23, 2009
dontbother10
  • 2220 Answers
SOURCE: set carb homelite chainsaw mod ut 10939
No response to CR.
Posted on Mar 13, 2010
SOURCE: I am looking for a homelite super 2 service manual
I have that saw. The manual states if you are using Homelite 2 -cycle oil read and follow the instructions on the package. If you use other than Homelite oil use 16 parts gasoline to 1 part 2- cycle oil, 1 gal / 8oz
Posted on May 26, 2010
I need to know fule oil ratio for homelite super2 chainsaw
Generally small tool 2 stroke engines run on a ratio of 50:1
That's 100ml of oil in 5L of petrol
Apr 03, 2016 | Homelite Garden
WHERE CAN I FIND A MANUAL FOR THIS CHAIN SAW MODEL UT10753
You did not say who the manufacturer is of your chain saw. Is it made by Homelite?
Go to this website: http://www.manualsonline.com/ and type in your chain saw manufacture and model
Feb 21, 2016 | Garden
How do I set idle on my homelite super2 chainsaw
Homelite XL 2 Automatic Chainsaw - YouTube
? 6:12
https://www.youtube.com/watch?v=qk6nk-JQ-zg
Apr 20, 2012 - Uploaded by Alec Ulm's Busted Knuckles
Homelite XL 2 Automatic Chainsaw ... free to shoot me a question or comment and I'll do my best to answer as accurately as I can . ... Homelite SUPER 2 Chainsaw OILER REPAIR & TEST RUN - Duration: ... HOW TO ADJUST A Homelite Carburetor - Duration: 5:01. by smallenginemaster1 177,482 views.
How to Adjust the Carburetor on a Homelite Super VI Chain ...
homeguides.sfgate.com > Construction & Remodeling > Siding
Homelite Super VI chain saws are equipped with a Walbro HDC diaphragm, and ...Adjust the idle mixture screw and idle speed screws clockwise one-quarter turn at a ...Homelite Super 2 Chain Saw Oil Type · How to Replace a Carburetor on a .... MyRidevisit'Cars-My Ride'navigation-www'4 · Sell Your Carvisit'Cars-Sell ...
Need carb settings for Homelite chainsaw - My Tracto
Jan 03, 2016 | Homelite Garden
Homelite textron 104664
Unfortunately it's almost impossible to repair a leaking gas tank on a saw
Feb 20, 2014 | Garden
My homelite chainsaw model# ut10520 has aoil leak from the flexible line at the base of the oil tank.
I input your model number and found 3 possible matches, "42cc/46cc Chain Saw UT-10520; SUPER 2 Chain Saw UT-10520 or SUPER 2 Chain Saw UT-10520-A".
I opened the first "Ref # 3" on "Figure A" I suspect is what you say is leaking. It is very inexpensive and available. I would order one and inspect it once recieved to determine an installation method. It does not appear overly difficult without the part in hand. Good Luck.
Homelite/Ryobi.com (authorized parts supplier)
https://www.gardnerinc.com/recons/disclaimer-lg.php - Agree; Choose “Product Line”; “Select OEM” & “Select Catalog” both to “Homelite Consumer Products”. A drop down list appears; self explanatory from here.
The numbers Homelite & Ryobi use do not match the numbers everyone posts. A careful inspection of your saw should find something that matches.
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
May 07, 2010 | Homelite Consumer Products 9.0 Amp, 14 In....
HAVE OLD HOMELITE SUPER XL AUTOMATIC NEED ON OFF SWITCH AND MAGNETO , WE HAVE NO SPARK AND HAVE DONE ALL THE OTHER THINGS . SER. NO 3G2550042 , THE NUMBER ABOVE THIS ONE IS , UT NO 10045-C
Is it this one? She has points.
http://www.acresinternet.com/cscc.nsf/ed1d619968136da688256af40002b8f7/57a3b86d6acae4e188256c260048b728?OpenDocument
You may find parts for this grand old Lady here:
http://www.acresinternet.com/cscc.nsf/673d78ec01557aea88256b00005457e6/53fd90eee11e3fe8882572a300167f51?OpenDocument
Last chance try here (parts and guidance):
ArboristSite.com Chainsaw thread (free to join)
http://www.arboristsite.com/forumdisplay.php?f=9
This is an international collection of chainsaw enthusiasts with a few 2-cycle mechanics and saw retailers thrown in. They are a good bunch and I am certain someone can help.
I did not see any Homelite (most makers have one) thread but did find this:
http://www.arboristsite.com/showthread.php?t=120583&highlight=xl+super
Be kind to her. HTH
Lou
Jan 18, 2010 | Homelite Garden
Need owner or service or both manuals for Homelite Super 2 16" chainsaw UT# 10654, SN HJ0110214
Homelite/Ryobi.com
Atta boy/girl
Lou
Sep 23, 2009 | Homelite Garden
Primer bulb is part of the fuel cap.
I have a Homelite Super 2 chainsaw that has a hole in the primer bulb on the fuel cap...will not prime. Where can
I find a replacement primer bulb fuel cap?
Jun 24, 2009 | Garden
IGNITION PROBLEM
You may have a difficult time finding those. I would go to the local mower shop and get an electronic ignition module and replace it with that. It will probably cost less than the points and condenser and make the saw more reliable too.
Please rate if this helps-
Mar 27, 2009 | Homelite Garden
Garden Logo
26 people viewed this question
Top Homelite Garden Experts
roeb
Randy Schumann
Randy Schumann
lnbn1975
Are you a Homelite Garden Expert? Answer questions, earn points and help others
