Yes it will. I suggest that you download Windows XP SP2, and Windows XP SP3 and save to an external USB key or burn to a CD-R. If you save the downloads to your HD, restoring to factory settings will most likely overwrtite your HD. So with that. I also suggest that you backup all your personal data, such as documents, pictures, favorite, email contact list, emal messages, and any other personal data that you will need.
Once you have finished the restore to factory process, place the USB key or CD-R in the slots/drive, and install SP2 first, check no restart button, then install SP3. Reboot and now do your Windows Updates.
The reason I suggest sp2, then sp3 before running Windows update, is to save you time getting your unit back in production. If you did a Windows update after the restore to factory process, you would most likely be prompted to download and install SP2, then all the patches and updates would follow fro sp2. This way sp2 updates sp1, then sp3 updates sp2, and finally the updates and security patches for sp3 are all you need.
McAfee - Again download the software to a USB key or CD-R. Before you start the restore, open McAfee, select help, about, and print out or write down your subscription key. You will need these when you reinstall McAfee on your restored unit.
Hope this helps.............
God Bless !!!!!!!
Yes indeed. If you restore, it will go back to the factory settings. But doing so will improve your system performance considerably. But after doing so, you should update your OS to the latest service packs (SP3 if XP) and also install you antivirus (if not previously installed automatically by restore) and update it.
Restoring will affect on ur update files but not on ur subscription.
Short answer: yes
long answer: yes it will ,but you should be able to keep that subscription at mcaffe's website
Have you tried restoring the computer to the original factory configuration? If you did not have the problem when you first received the laptop, the restoration will fix it. (Page 70 of the Setup Guide -- Factory Image Restore).
If the restoration fixes it, that means that some configuration change caused the problem, most likely an update. If you keep track of future updates you can discover which one triggers the problem when it recurs.
If the restoration does not fix it and the computer did not originally have the problem, that means that a hardware problem has developed.
