ENGLISH: Good morning. My question is: The Konica Minolta Bizhub C652 printer has an error on the screen that says C 6301. How can I fix it? Thank you
https://www.google.com/search?q=Konica+Minolta+Bizhub+C652+printer+error+C6301
• The fan lock signal remains HIGH for a predetermined continuous period of time while the motor remains stationary.
SOURCE: estrella de validacion
Translation from Espaniol: when booting windows I get a star on the toolbar that says my version of windows is not valid and puts the ondo of the screen in black as I can make it out, that translation of what he said. My Advice: You should get a validated or at least a non-fake version of windows. Translation: Usted debe obtener una validación o, al menos, no falsas las versiones de Windows.
SOURCE: Problema con impresora MFC-3420C
Hi there
Error 41 means there is a major problem with the printhead, usually
requires a print head replacement.
My advice is to take it to a
Brother service centre while if it is under warranty.
If it's out of warranty they are usually a throw away job, the heads cost as much as the printer.
Sorry I know what it feels like, just have a go and see what you can do, clean the heads and so on.
All the Best and good luck: Pineworks
SOURCE: compre un motor de puerta
La ?nica forma que conozco de hacer esto consiste en hacer girar el abridor de 180 grados.
Si necessita mas asistencia, permita que sepa. Si esto ayuda o resuelve el asunto, por favor lo valora y da una recomendaci?n para mi respuesta. Gracias, Jose
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
