My flatscreen tv manual controls are causing tv to act erratic. Is it possible to disconnect controls and just use remote for a temporary fix?
    Top Expert:
  • Televison & ... Master
  • 76,125 Answers
Yes. If the remote control works properly, you can. Be sure the infrared receiver at the front panel not disconnected.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Posted on Sep 12, 2019
SOURCE:
Sparky-UK
  • 129 Answers
SOURCE: manual
hello, please find the manual for your remote and the codes here:
http://www.ofausa.com/remote.php?type=URC3220
just right click on the download links and you are set.
Many thanks
Mark
(www.sparky-uk.com)
Posted on Dec 21, 2007
freetek
  • 5569 Answers
SOURCE: tv won't operate off remote control
Unless you had the remote tested by Samsung, the test isn't comprehensive; it will only tell if the remote is putting out infra-red of some kind, that type of tester cannot determine if the codes are correct or complete. The only true test would be one in which you had a second TV or a second, known working remote. Even using an oscilloscope with an infra-red detector wouldn't help unless one had the specific code sequences available, it would only appear as a pulse train.
Posted on Sep 22, 2008
SOURCE: need a code for rca universal remote control
http://www.xdiv.com/remotes/
Posted on May 30, 2010
  • 11800 Answers
SOURCE: protron flatscreen tv remote and tv controls not
The control chip is dead. Since the chip is on the mainboard it also must be completely replaced.
The problem is not in the price - the board and the replacement labor by a repairman will cost you less than $300 - it will be in finding the board in the first place: Protron is a no-name manufacturer that makes its tv's from separate parts that it buys from other manufacturers at the cheapest price possible, they only assemble them also the cheapest way possible; as such you can't get parts from them , they don't have any - especially if the tv is out of production for more than a year(all the warranties have expired and they no longer have to fix them). Because of that all you can do is to try to find a second hand board online or at a repair shop. Before calling a repairman make sure it can get the board at a reasonable price.
Posted on Aug 17, 2010
Testimonial: "thanx azraelsrl,very helpful"
SOURCE: Yamaha RX-V1000 volume control erratic, remote
Hi.
The volume knob issue alone sounds like it's hardware-related and therefore not easily fixed. Also, since the remote appears to be working (the LED's are lighting up), but the unit is not controlled anymore, the IR sensor is probably faulty as well. I would seriously consider sending this AV receiver in for repair. If it's still within warranty, you shouldn't need to pay anything for the repair.
Manual for your receiver: http://www2.yamaha.co.jp/manual/pdf/av/english/re/RX-V1000.pdf
It's not much but I hope this helps.
D
Posted on Aug 21, 2011
3.9 ltr V-6 running very rich, acts like it is choking out when trying to accelerate and blows black smoke. Is this a fuel problem?
Yes, the engine is being overfuled if blowing black smoke. Possible internal leak of fuel pressure regulator. Possible sticking/stuck EGR valve. Possible computer supplying more fuel due to a sensor supplying false information. A scan tool will be required to determine if one or more sensors is supplying erratic info
Jan 04, 2016 | 1989 Dodge Dakota 2WD
How do I program it to a Magnavox tv flatscreen
Programming an RCA Universal Remote - YouTube
? 2:46
https://www.youtube.com/watch?v=MZd4yBivcZ4
Nov 10, 2008 - Uploaded by alpharedecho
... how to program an RCA Universal remote for operation with your TV. ... Still in able to work or my rca flat screen and my zenith. .. ive .... I'd do it over and over and the power button on the remote just turns off in the end?.
Magnavox TV codes - Magnavox TV set. Buy, reviews ...
magnavoxtv.org/magnavox-tv-manual/magnavox-tv-codes/
Helpful Resources for Magnavox TV codes. Press and hold ... Note: If some buttonsdo not operate your equipment, try one of the other codes for your brand. TV.
RCA Universal Remote Control- Target Programming ...
Dec 25, 2015 | RCA CRK76TE1 UNIVERSAL REMOTE - With...
8 -in-1jumbo universal remote code for hisense lcd flatscreen tv
Click here to download the manual to your remote control. It has all details.
Aug 14, 2012 | Innovage Jumbo Remote Control
Samsung TV remote. I noticed today my TV remote wasn't working. I changed the batteries and noticed there had been some leakage from the AAA batteries. Since changing the batteries the 8 buttons on the top...
Giving you some hints. Battery leakage is one enemy of tv control and other remote control. They can corrode your battery spring contact, give contact bridges with neighboring tracks that can cause erratic behavior of your remote.
Some repairs can be done but doesn't guarantee success. First is try to clean the corrosion on battery contact = no power usually. Erratic behavior cause by contact bridging = battery leak residues.
Opening a remote control. Some have screws on its small foot. Covered by a rubber or sticker. Some are notch clip in strategic location you have to fry that one by one, opening first on its weakest side. In some don't want to be open.
Cleaning the board by a soft eraser is one way. After you open the remote. Commonly the button area where contact takes place.
If the first procedure and cleaning doesn't work. Buy new remote or use universal remote controller.
Aug 23, 2009 | Samsung TV Remote Control
How do I replace the Vertical Output IC
Replace the Small Signal Board Part #313912725871
This is a common problem withis TV.
Jul 30, 2009 | Philips 50P8341 50" Rear Projection...
New flatscreen/remote not working
Try these simple trick to find out yor remote control working or not....
Point the remote control towards the Camera of a Mobile Camera phone,with the camera on. While pressing remote, we can see a light (Infra Red) coming from its IR LED through the Mobile Camera if the Remote is working.
If your Remote is ok, then the problem with the Remote sensor or related components of the device.
Oct 16, 2008 | RCA DIRECTV Satellite Remote Control
Kidz Remote Toshiba TV Code?
Hchuppa I was wondering if you could display the codes for the tv plz?
Aug 15, 2008 | Televison & Video
Code for HP Plasma Flatscreen
Hello, follow this link to download the manual and the codes for your remotes:
http://www.ofausa.com/remote.php?type=URC3605
just right click and save as on the download links.
if this does not work you can try the search method,
you do this by either holding down the device button eg: TV or if you have one the "magic" button for three seconds, a light should then flash twice to say you have done this correctly.
then press the keys 991 then the power button.
you must now press the channel up key (ch+) possibly upto 150 times while the remote cycles through every code.
Once your tv or device switches off stop pressing the ch+ key and press the power button to make sure it switches back on,
(if you press ch+ too many times you can go back by pressing ch-)
When complete press the magic or device key again to save the settings (light should flash twice to confirm)
Many thanks
Mark
(For replacement remotes visit www.sparky-uk.com)
Jan 13, 2008 | One For All URC-3605 Remote Control
Tv turns on manually, but auto flips through channels and you can't use remote
Found this in another forum (www.hometheaterspot.com) and it fixed my remote problem:
"...it's possible that one of the front panel buttons is "stuck" or shorted, and this could cause the TV to ignore commands from the front panel or remote. But this should also cause the Power command to be ignored, too. You might try pulling off the front panel and disconnecting the front panel buttons and then see if the remote works."
Oct 19, 2007 | Mitsubishi WS-65511 65" Rear Projection...
Wont come on
try pressing one of the number keys instead of the power button on the remote
Sep 06, 2007 | Beko 324250WN 28" TV
Televison & Video Logo
Top Televison & Video Experts
Ekse
