HP Compaq Presario V5000T Notebook Logo
Posted on Sep 14, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have similar problem
I bought 5 year ago of my Compaq presario V5232. I replaced battery and directly connected to it but it won't power up and green light is still on. Moreover I see in lapto have flick light on and off.
Can anybody help me?
Anonymous
Level 3:
President:
  • Master 1,187 Answers
  • Posted on Sep 14, 2009
Anonymous
Master
Level 3:
President:
Answers
1187
Questions
0
Helped
527987
Points
4102
The battery is too low for the power adapter to charge it and power up the laptop at the same time.
Remove the battery. Start the computer using the power adapter (no battery).
Once the operating system settles.... put battery back in and let it charge up.
Hope this helps!
2answers
I think I have a PMU problem: just bought a new battery for my 6 year-old Compaq Presario and it worked fine until a week or so ago. When plugged in the battery shows a full charge (which previously would...
It sounds to me that the battery is not connecting to your computer. Is it possible that the terminals have been damaged? Or some other issue that is disconnecting the battery from the computer?
Fit my Compaq Presario CQ61?
accu Compaq Presario CQ61 100 percent compatible with you Compaq Presario CQ61. I bought two Compaq Presario CQ61 batteries from http://www.accukorting.com/compaq-presario-cq61.html two weeks ago, I felt very surprised, because it fits nearly as good as the original battery.
1helpful
Compaq Presario CQ60 won't turn on
If you already replaced the motherboard then try replacing the power cord. If you meant you replaced the cord already, the it might be your motherboard is bad.
Compaq Presario CQ61-313US Notebook PC won't power
try to remove first your battery and use only the adapter.
We have a compaq presario cq 60 bought in Canada and it's about 3 years old. Until yesterday, the computer battery would hold a charge for about 45 minutes (yes, we know we will have to replace the...
You need to replace your old battery. Don't over charged your battery. If you are using your laptop in your house it is better not to use it with battery. Just use the power adaptor/supply only. Then make sure you will drain the battery let say once a week. =)
I have a good day estimated presario 700 laptop and I need help because they will not start, I connect the power supply and keeps the battery light turned amber, in conjunction with the direct power. no...
unplug the power cable from the laptop
remove the battery then press the power button for 5-10 secs
plug in the power cable to your laptop WITHOUT the BATTERY
try to turn on your computer if still doesnt work try a known good A/C adapter if still doesnt work then mobo needs to be replace
I bought this computer 5-6 years ago. And it has been in the box since. Is it capable of wireless connection
It is not wireless capable out of the box. However, it has 2 free PCI slots for an internal wireless card and several USB ports for a USB wireless adapter.
I hope this helps.
Compaq Presario V2000 battery
if the computer will turn on with it plugged into ac power than it is most likely the battery. batteries on these machines are cheap. Mine died after a year
1helpful
Forgot bios password
1. Shut down the computer. If you are unsure whether the
computer is off or in Hibernation, turn the computer on,
and then shut it down through the operating system.
2. Disconnect all external devices connected to the computer.
3. Disconnect the power cord.
4. Remove the battery pack by following these steps:
a. Turn the computer upside down with the front panel
toward you.
b. Slide and hold the battery release latch 1 to the left. (The
front edge of the battery pack disengages from the
computer.)
c. Lift the front edge of the battery pack 2 and swing it
back.
d. Remove the battery pack.
5. Remove the RTC battery from the socket on the system
board.
6. Wait approximately 5 minutes.
7. Replace the RTC battery and reassemble the computer.
8. Connect AC power to the computer. Do not reinsert any
battery packs at this time.
9. Turn on the computer.
All passwords and all CMOS settings have been cleared.
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
