Please be more specific with your problem. Does it even start? Does it have power? Does it fill with water? Does it spin or agitate. Help me isolate the problem.
Hey there, welcome to Fixya! The above answers were pretty helpful, did you fix your problem with them? Did you check the manual for further instructions? You can find a PDF copy here: Bosch Classixx 5 Manual
this is because the water can't evacuate . check the pump trap filter and make sure there are no blockages. you will probably find water still i the machine when this happens. There might be a blockage up in the hose pipe before the pump. Good luck
Sounds like you have a broken belt or a bad motor. The easiest way to tell if the belt is bad is to reach inside the drum and turn it. If it turns very easily, you probably have a bad belt or something has caused the belt to jump off, such a s a loose pulley or bad bearing. If it feels like there is a good amount of resistance, or a kind of "winding up" noise, then the belt is still on and you likely have a bad motor. Also, you could just scoot the macine out, unplug it, and remove the back cover a look inside to see if the belt is still on the pulleys. Good Luck!
