How to remove front grill from arlec reh 216 heater
2 Suggested Answers
SOURCE:
  • 4 Answers
SOURCE: rennai gas heater, REH-23DFT-N burner makes a
There could be dust on the fan causing it to become un ballanced and start causing vibrations through the unit...
Posted on Aug 05, 2010
Pilot lite will not stay on when I release the igniter pressure knob REH-18-N wall heater!
IS there gas? YES ok. So if you can get the pilot lit, but when you let up on the button it goes out. Few things to check. On some heaters the manf. install a safety switch to drop the pilot out if its not venting or if its over heating.
Jan 01, 2017 | Heating & Cooling
Reh 252uc - Service or Replace? Smell gas when turned off....
You may have a small gas leak. Use a water sprayer with dish soap mixed with water and spray the gas fittings. If bubbles develop, you have a leak. Careful not to spray any electronics!
Jul 20, 2014 | Rinnai Heating & Cooling
Ù?دÙ? Ù?Ø´Ù?Ù?Ø© فÙ? سÙ?ارتÙ? اÙ?تÙ?ا
Generic OBD II Diagnostic Trouble Codes
DTC CODES P0200 to P0299
P0200....Injector Circuit
P0201....Injector Circuit - Cylinder 1
P0202....Injector Circuit - Cylinder 2
P0203....Injector Circuit - Cylinder 3
P0204....Injector Circuit - Cylinder 4
P0205....Injector Circuit - Cylinder 5
P0206....Injector Circuit - Cylinder 6
P0207....Injector Circuit - Cylinder 7
P0208....Injector Circuit - Cylinder 8
P0209....Injector Circuit - Cylinder 9
P0210....Injector Circuit - Cylinder 1
P0211....Injector Circuit - Cylinder 11
P0212....Injector Circuit - Cylinder 12
P0213....Cold Start Injector 1
P0214....Cold Start Injector 2
P0215....Engine Shutoff Solenoid
P0216....Injector/Injection Timing Control Circuit
P0217....Engine Coolant Over Temperature Condition
P0218....Transmission Fluid Over Temperature Condition
P0219....Engine Over Speed Condition
P0220....Throttle/Pedal Position Sensor/Switch 'B' Circuit
P0157....O2 Sensor Circuit Low Voltage (Bank 2 Sensor 2)
P0158....O2 Sensor Circuit High Voltage (Bank 2 Sensor 2)
P0159....O2 Sensor Circuit Slow Response (Bank 2 Sensor 2)
P0160....O2 Sensor Circuit No Activity Detected (Bank 2 Sensor 2)
P0161....O2 Sensor Heater Circuit (Bank 2 Sensor 2)
P0162....O2 Sensor Circuit Malfunction (Bank 2 Sensor 3)
P0163....O2 Sensor Circuit Low Voltage (Bank 2 Sensor 3)
P0164....O2 Sensor Circuit High Voltage (Bank 2 Sensor 3)
P0165....O2 Sensor Circuit Slow Response (Bank 2 Sensor 3)
P0166....O2 Sensor Circuit No Activity Detected (Bank 2 Sensor 3)
P0167....O2 Sensor Heater Circuit (Bank 2 Sensor 3)
P0168....Fuel Temperature Too High
P0169....Incorrect Fuel Composition
P0170....Fuel Trim (Bank 1)
P0171....System too Lean (Bank 1)
P0172....System too Rich (Bank 1)
P0173....Fuel Trim Malfunction (Bank 2)
P0174....System too Lean (Bank 2)
P0175....System too Rich (Bank 2)
P0176....Fuel Composition Sensor Circuit
P0177....Fuel Composition Sensor Circuit Range/Performance
Nov 29, 2010 | 2005 Nissan Altima
Do i leave pilot lite on reh-30 rinnai heater when not using?
No if you don't plan to use it switch off the pilot for safety reasons and also for longer life of pilot system.
Nov 05, 2010 | Heating & Cooling
Honeywell HZ517 Baseboard Heater
You can try to disassemble the heater and look for something wrong like a loose wire: in order to do so: Unplug the heater and let it cool completely before disassembling it. Remove the rear grille and the control knobs. Remove the front grille by unscrewing the fasteners on the back of the housing. Remove the front grille by lifting the control housing and pulling the front grille toward you. The motor, fan, and heating element are now accessible for testing and repair. Remove the thermostat from the control housing and disconnect the wires. Remove the heat control's mounting screws and clips to access and disconnect wires. Good luck
Nov 28, 2005 | Honeywell HZ517 Baseboard Heater
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Donni Steen
Marvin
Marvin
