Ican,t get new SBS channels on my Vivotv - Televison & Video
I don’t have a manual on how to use my new tn. All I am getting are the ordinary channels and sbs. I would like to know how I set up tp gain access to all channels, also how do I record
hi there, could you please expand on the question, such as.What is 'sbs' ? and which other access to channels are you referring to ? also why would you think you can record on your tv ?. I may be able to help with a manual, but in order to do so I need the make and model number.
Oct 12, 2017 | Televison & Video
How to reset Windows SBS administrator password?
Reset Windows SBS administrator password seems to be a tough thing. But don't need to be panic. There are two effective methods for you to reset Windows SBS admin password. The first method may be a little easier than the second one.
Method one: Reset Windows SBS 2011 Password with Windows Password Genius
1. Download iSunshare Windows Password Genius, launch it and insert USB or DVD/CD into your accessible computer.
2. Create a Windows SBS 2011(Windows Small Business Server) password reset disk by USB or DVD/CD. Select right removable device and click "Begin burning" button
3. Insert the USB or DVD/CD into your locked Windows SBS, set Windows SBS boot from USB or DVD/CD.
4. Choose Windows SBS 2011 and user account, Click "Reset password", then "Reboot" computer after successfully reset password to blank
Method two: Reset Windows SBS 2011 Password with Start Disk
1. Restart your Windows SBS 2011 with the installation CD or any USB/DVD you can boot from and get access to the HDD drive.
2. Booted from SBS 2011 media, select Next
3. Select Repair your computer
4. Select your partitions and installed Windows version and click Next
5. Select command prompt
6. Change directory to the access the system 32 directory. Then your original C:drive is changed to D: or E: depending on the number of drive and partitions you have on that system.
7. Rename Utilman.exe to Utilman.old and copy cmd.exe to Utilman.exe, exit and reboot
After the reboot select the Ease of access icon
8. You will get a command prompt and use net user admin user password to change the password
At the user logon screen, press a combination of Windows KEY+U, then the CMD.exe will appear. Type net user "Username""new password"
After you changed the password, exit the command prompt and login in with the new password. Don't forget to change the Utilman.old back to Utilman.exe. It could be that you will need to reboot with your media to change the Utilman back.
Aug 09, 2013 | Microsoft Windows Small Business Server...
Creative SBS 370 2.1 - left audio channel is not working
This is coz of one carbon track of dual potmeter gone bad due to prolonged use.
Jan 28, 2013 | Creative Labs SBS 370 Computer Speakers
No sbs didital channel coming up
You first need to ensure if you have any SBS digital signals in your area. I take it that you are in Australia. Go to this website for more info. If this is not what you are looking for let me know.
http://www20.sbs.com.au/transmissions/
http://www20.sbs.com.au/transmissions/index.php?pid=1
If you have received SBS signals before and now you aren't there may be a setting on your tv that changed the component input from SBS to something else. Check to make sure the component inputs that the signal is coming in on is selected on the tv. I sure hope this helps you. If not, give me a little more info and maybe I can help a little more.
Mar 08, 2010 | Vizio VX37L Television
Poor tv reception on my new lcd screen
Hi, sounds like the antenna. Maybe get an Aerial company to check it out for you as you might not be picking up a strong enough signal.
Dec 27, 2007 | Televison & Video
Televison & Video Logo
15 people viewed this question
Top Televison & Video Experts
Ekse
