SOURCE: setting woods 1600 timer
you can get your instructions here and print them off.
http://www.woods.com/canada-timer-instructions.asp
There is a complete list just choose the one that you have. Please don't forget to rate me on this.
Thank you
SOURCE: instruction manual missing for Woods Industries
Especially for you - click on this link and smile: http://www.ccixpress.com/cci/Marketing/Woods_Canada_Timer_Instructions/49556.pdf Pssssss - don't tell anybody else. :)) Rate me, plz.
Testimonial: "Unbelievable! thanks very much for your help...whoever you are. I had given up...when this email arrived. The manual was exactly the right one... "
SOURCE: how to program a woods TD1000 indoor timer
Here's how to set Woods TD1000 timer
This is older timer with backup battery. Plug in timer to see if battery will work. Display shows when battery is charged. No display, then timer is no good.
TD-1000 timer has 8 on-off functions per 24-hour day ...newer timers each offer 7 day function with choices of each-day, week-day, or week-end programming. The wider choices with newer timers may explain why TD1000 instructions are hard to find
Timer has 5 buttons + reset:
TIME MODE PROG HOUR MIN
Set time
Press and hold TIME > use Hour to set hour, Min to set minute
Release Time button ... correct time should show
Program: Capacity for 8 on-off times per day
Press PROG to set first ON time
ON and number 1 are displayed on left
Use hour and minute button to set ON time
Press PROG to confirm
Now, OFF and number 1 are displayed
Use hour and min key to set OFF time
When 8 programs are set, Press MODE key.
Choose Manual OFF. Manual ON, Auto ON, Auto Off
To use programs, select Auto ON
DST daylight savings time has to be done manually.
Press HOUR MIN button simultaneously > timer set up one hour
Repeat again and timer goes back one hour
Do not plug timer into extension cord > must be plugged into wall
SOURCE: I need the instruction sheet
Here is the manual for Woods TD2200
http://waterheatertimer.org/pdf/Woods-49377-TD2200.pdf
Plug in timer.
Let rechargeable battery charge.
Once battery is charged, you can remove timer from plug so programming is easy.
If battery will not charge, then timer is no good.
SOURCE: Instructions to set Woods indoor timer 59377
Open following link to identify timer and download manual
http://waterheatertimer.org/Woods-timers-and-manuals.html#59377
To set current time, press and hold clock button while pushing hour and minute buttons.
Then release clock button
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
