Question about Pool & Spa
How to replace a circuit board for a ruud pool heater, model P-R406A-EN-C. The temp is no longer visisble.
    Top Expert:
  • Pool & Spa Master
  • 10,134 Answers
If pump running and voltage from transformer replace temp sensor
Posted on Sep 12, 2019
SOURCE:
johnsonr1
  • 91 Answers
SOURCE: Rheem model p-m266a-en-c digital gas pool heater runs, shuts down
CFH is call for heat not sure what spk is, but will find out and let you know.
Posted on Aug 22, 2009
  • 139 Answers
SOURCE: Service light comes on our Raypak RP 2100 pool heater.
this usually indicates a high limit condition.you must first ascertain if you have a component failure or a true high tempature condition.your model has 2 limit controls and they are both located in side panel on water in/out header
Posted on Sep 19, 2009
  • 990 Answers
SOURCE: Pool Heater Mis-reading Temp.
Your temp sensors are on the heater, a small tube that slides into the water manifold, usually on the left side. On the remote it will be in one of the pipes coming from the pump or the filter. If it is after the heater you should move it to between the filter and heater. It will be a tube that is in the pipe with a stanless steel clamp holding it in place.
To find out wich one it is you will need to remove the remote from the system by takeing the wires that go to it from the wireing inside the heater and wire nuting the wires in the heater together. If the heater runs normal then it is the sensor for the remote if not it is the sensor for the heater. Let me know how you do and if need be we can get a little more specfic for your system. good luck.
Posted on Mar 29, 2010
thepool
  • 78 Answers
SOURCE: Pool Heater with communication (CE) Error
Code "CE" stands for communication error and describes a fault between the mother board and the display. I doubt it's the relay causing it though...
Posted on Apr 23, 2010
  • 64 Answers
SOURCE: H-series Electronic Gas Pool Heater H400: I have an H400 with digital temp control panel, th...
It is likely the keypad that has gone bad. Not difficult to replace. But you want to be sure thats what it is, as it is an electronic part, that is usually not returnable. The part number would depend on the model of the heater. Likely it is a h400idxl2 heater.
Posted on May 19, 2010
I have a Ruud 206A-EN-X Pool Heater and I get anr error message "ROL" ercvice required. What do I need to do?
it is the rollout fuseable link replace then check gas pressure if too low need new gas line or meter you will see sooting this means the heater overheated also if all others ok could have been windy day and it rolled out in which you need a windstack on the top
Jul 07, 2014 | Ruud Pool & Spa
Pool heater
hi please try to reset the circuit board, by turning the heater on/off from electric power, if don't work you got to replace the water temp sensor located inside the circuit board (BROWN WIRES) if still display the same problem try new circuit board.for this type the heater a master temp, pcb will work rev.R-13 Good luck. if you need part # let me know, remenber before replace any electronic parts in heater SHUTT THE POWER OFF.
May 04, 2013 | Pool & Spa
Pilot won't light
if gas check for cobwebs if ok replace pilot generator
Feb 15, 2013 | RAYPAK R406A DIGITAL MODEL 406 wCUPR0...
I am getting a ROL code on my raypak 406 gas pool heater. Does anyone know what this means?
roll out senor bad replace but check gas pressure if too low it will overheat once gas is ok then replace fusible link and clean outside of het exchange
May 11, 2012 | RAYPAK R406A DIGITAL MODEL 406 wCUPR0...
I have a RP 2100 Raypak Pool Heater Model number C-R185-EN installed about 1996 and used very little through out the years the front service light is on-- red --the back circuit board fault shows a sensor...
The part number for the thermistor for your heater is 005299B, officially called the temperature sensor IID it is also refered to a temp sensor or temp sensor kit.
John
Jul 09, 2011 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
Pool & Spa Logo
15 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
