Microwave Ovens Logo
A
Angela D Spoto Posted on Sep 11, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I spilled soup into the bottom of my GE Advantium. I can see what looks like a drip tray but don't know how to get to it.
Franco Dosil
Level 3:
Top Expert:
  • GE Master 10,542 Answers
  • Posted on Sep 12, 2019
Franco Dosil
GE Master
Level 3:
Top Expert:
Answers
10542
Questions
0
Helped
377253
Points
178965
Hi Angela, as a first step disconnect the device from the outlet, then you must remove the lid and see how accessible it is to clean it
Remove all the liquid, clean and let it dry very well
I hope you can solve the problem
Regards Franco Dosil
Hola Angela, como primer medida desconecta el aparato del tomacorriente, luego deberas sacar la tapa y observar que tan accesible esta para limpiarlo
Retira todo el liquido, limpia y dejalo secar muy bien
Espero puedas resolver el problema
Saludos Franco Dosil
3 Related Answers
MicrowaveSvc
William Miller
  • 9179 Answers
  • Posted on Dec 25, 2008
SOURCE: Broken bottom latch on GE Advantium 120
You have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) that demonstrates how it's done.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Anonymous
  • Posted on Oct 31, 2009
SOURCE: GE advantium oven does not microwave
I have had this same problem and have replaced the door switch a couple of times. It is very easy and can be done with out taking the unit off the wall.
Anonymous
  • Posted on Oct 09, 2010
SOURCE: Black Metal Tray for GE Advantium Oven
wiring solution for ge advantium 240
The renter threw the tray to adapt the microwave to convection oven. I need to know where and how much a new one costs?
Are you talking about the black round pan? I don't think I have any other parts in my Advantium for speed cooking or convection. I occasionally just use an oven safe dinner plate. Sorry I can't help with replacement parts.
1helpful
2answers
6helpful
Control panel "locked" on ge advantium 120
You might have set the child lock. Look in the manual. It is on P.36 in my manual.
I want to replace the door
I do not think you can change the door. I can be wrong though. call ge at the number on this link.
http://products.geappliances.com/ApplProducts/Dispatcher?REQUEST=SPECPAGE&SKU=SCA2001KSS&SITEID=GEA&TABID=3
Good Luck and Please Rate
6helpful
2answers
Broken Bottom Latch Pawl GE Advantium 120 Microwave
Power level
Hi cindeet,
I don't have this particular model, but have experience with other GE stoves & ovens. Looking at the control panel for an Advantium 120 at the link below,
http://www.geappliances.com/products/introductions/advantium/downloads/advantium_brochure.pdf
I'd start by pressing the "Power/Temp" button, and then turn the knob to select which power level.
There is also a Help menu shown (upper left corner of the photo I'm looking at - page 4 of the PDF document referenced above.
Let me know how this works for you - thanks in-advance.
Jon
2answers
I just found one for $33.95
http://www.partstore.com/GetModel.aspx?MfgName=General+Electric&BrandName=General+Electric&ModelNumber=SCA1001FSS001&page=3
1helpful
Grinding noise/noisy turntable
Your turntable motor is probably failing.
If you or someone you know decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
Normally you have to remove the bottom cover of the microwave (looking up from the stove top) and then the motor is accessible.
We're happy to help and we appreciate your thoughtful rating of our answer.
GE Advantium SCA 1001HS
Should be able to get to the lamp by removing the grill.
Top GE Microwave Ovens Experts
vince
NOEL
NOEL
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
