SOURCE: I cannot get my Nespresso Lattissima to clean out
Have to pull out the entire container and push it back into the unit so it fully connects with the machine. Then try again.
SOURCE: how do I use print screen on my Acer Aspire
You need to PASTE the Item in a Program. Open Word and a Blank Doc and the Right Click PASTE.... should be there...:)
SOURCE: After descaling le Cube two flashing buttons won't stop so can't
I had the same issue. This is what a did:
Turn off the machine
Remove the tray/container and leave it outside
Turn on the machine and this time the power button should be flashing (preheating) then hold both cup buttons for 3 sec and it will be back to normal opertion....
For some reason the sensor needs to read that the tray/container is out of the machine...
SOURCE: menu screen keeps popping up instead of "ready to
There is air in the lines and it is blocking the water flow...
Here is a tip that will help you getyour Keurig to prime...
Keurig CoffeeBrewer will not prime
heatman101;;'
SOURCE: Brand new Nespresso Inissia M105 won't heat the water
Just a brief addition, I don't have the Magimix model, but I have a similar one. It loses it's programmed settings if it is unplugged or switched off at the wall, but if you leave it plugged in but turn it off with the switch at the back it keeps the settings you have put in. It draws virtually no power when it's switched off with the switch on the machine, (I checked it with a power meter).
Just thought I'd share that with you.
