My light is flashing on and off when i make my coffee like it would if u set the timer what would be causing this ? my coffe does not seem to stay hot long after it is donr perking. i no it only stays on for 2 hrs and shuts off but usaly my second cup of coffee is luke warm.
the coffe make is on a sencer timer built in coffe make for securty reasons its shots off after so many min. they built them that way so just in case someone forgets to turn off coffe maker and no ones home and burnes the place down.
You need to swivel the brew basket cover until it locks for the coffee to grind. Then turn the machine on and the coffe will grind. , then turn the machine off, add water and press the auto on to use the auto timer.
Hi
You have finished the descale process and your descale light should be gone. Put a fresh tank of water on the machine and then open the steam knob. This should clear the water light and your machine will start heating again.
I was able to fix my little problem. I unplugged my coffe maker and waited 'bout 10 mins for the whole thing to shut down. Once the clock shut off, I reset the time. Secondly, I pressed the on/off button and held it in for 2 seconds until the red light started flashing. I set H to 1 and M to 59(I have never seen this before). anyhoo, afterthat, I set the timer to the exact time I wanted to smell my freshly brewed coffee. This morning, the red light seemed to stay on and kept my coffee nice and hot.
Press and hold the TIME button for 2 seconds. The green TIME light will come on and display will read 12:00. The unit is now in the timer programming mode.
Press "HR" and "MIN" button to program start time. Small dot in upper left corrner signifies clock is programmed for A.M. No dot in upper left corner means clock is programmed for PM.
The Timer Display and LED light will flash 5 times to indicate that timer is now set. Press and release the TIME button. The green TIME light will come on.
I never really use this coffe maker. someone gave it to me. and i am not sure how to set the timer to have the coffee ready when we get up in the morning.
The wavy lines indicate the carafe pre-heat function. When it is ON the red light blinks for several minutes and the goes on solid. It doesn't start brewing until the light is solid red. Mine also doesn't seem to keep hot also.
After setting the clock to the correct time . then Press the Set delay then the HR and Min you want the timer to come on. Press the brew strength for your preference. then press the Select Twice to change Led light to Daily Brew. and now it will come on at the selected time.
