COULD YOU GIVE ME CODES TO A ZENITH TV THANKYOU
Code Search
If after trying “Direct Code
Entry” your device does not
respond, or if your brand is
not listed, try doing a search
of the code library for your
code by following the steps
to the right.
1. Manually turn on the
device (TV, VCR, etc.) to
be controlled.
2. Press and hold the SETUP
button until the red
indicator stays on, then
release the SETUP button.
3. Press and release the
desired Mode button (TV,
VCR, etc.). The red
indicator blinks once,
then stays on.
4. Press the CHANNEL UP
button repeatedly (up to
300 times) until the device
to be controlled changes
channel. The red indicator
blinks, then stays lit.
5. Press and release MUTE
to install the code. The
indicator light goes off.
Most users will want to
store VCR codes under the
VCR button, Cable codes
under CBL, etc. If you want
to store a VCR code under
CBL, etc., first follow the
procedure for Direct Code
Entry and press CBL in step
2 of Direct Code Entry, then
enter ANY VCR code in step
3 of Direct Code Entry. Then
follow the steps above for
Code Search.
ZENITH .. 0121 0009 0050 0078 0091
....... 0138 0059 0131 0038 0111 0134
....... 0153 0064 0004 0135 0226 0227
....... 0245 0247 0252 0266 0288 0310
....... 0338 0358 0023 0058 0039 0001
Here are some three digit codes:
ZENETH
000, 001, 004, 009, 023, 038, 039, 050, 058, 059, 064, 078, 091, 111, 121, 131, 134, 135, 136, 153, 226, 227, 245, 247, 252, 266, 288, 310, 338, 358
Zenith
083, 151, 152, 153, 154
