Put a fresh battery in each one after weedeater and I had cooled down but neither one would run again.
SOURCE: Poulan 17'' Gas Weedeater keeps dying!
Hello su2yak2:
From your Description it Sounds like the Exhaust Port or Muffler is Restricted with Carbon Deposits, the Carburetor Metering Pump Actuator Gap is Incorrect.
>>The Following is a Basic Instruction File for Doing a Diagnostic on the Engine for this Problem. Any Input is Appreciated.
>>**Remove the Muffler and Make Sure the Exhaust Port is Clear.
>>If it is, then Try to Start the engine with the Muffler Off.
>>If it Starts and Runs Properly, then Clean the Spark Arrestor Screen in the Muffler or Replace the Muffler if Required.
Is the Fuel Line from the Fuel Filter Staying Full of Fuel?
The Carburetor Metering Jet Actuator is Set so the Pump Diaphram Dowl is Just Touching the Actuator Arm. These Components are Located Under the Cover with 4 Small Screws Holdong it to the Carburetor Body.
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
SOURCE: RV air conditioner. Compressor running, fan stops before cool
The fan motor is getting hot and going off on the internal overload in the motor.
This is caused by either a low voltage, a bad capacitor, or tight or dry bearings in the motor.
To check the bearings turn the power off to the unit, then spin the fan blade if it spins freely then the bearings are ok.
To check the capacitor you will need some kind of tester or you can buy a capacitor and replace it, that's what a lot of people do. They usually don't cost very much.
To check the voltage you will need a voltmeter and measure the volts at the unit.
SOURCE: Ryobi edger, trimmer, weedeater was working fine
If the trimmer has fire, (spark) Then:
check the fuel lines for cracks/breaks. If they are o.k., then:
You will need to disassemble the carburetor and spray
with carb.cleaner. Make sure the small screen is free of debris.
(Should be able to see daylight through it.) Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152),
to clean the small portals in carb. These portals can
become blocked. Reassemble and start.
If you need further assistance, just let me know.
Jim
SOURCE: Hedge trimmer starts fine then stops after 5 minutes
Carburetor high speed adjustment ( screw nearest the filter ) open ( counterclockwise ) 1/2 turn.
Adjust again as needed to run when hot.
make sure the gas mixture ratio is as required.
Henry
SOURCE: Troy-Bilt TB70SS will not start
Hi. Go to any auto parts store and get a can of starter fluid. Have a helper squirt a little into the air cleaner while u start it up. Then continue to squirt the starter fluid to keep it running until the engine sounds good again. J.
