Washing Machines Logo
elia lopez Posted on Sep 10, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Put back together water inlet on haier hlp24 portable washer ...i removed to clean out and now dont know how to put back together
ftykjg
Level 2:
New Friend:
  • Expert 87 Answers
  • Posted on Sep 11, 2019
ftykjg
Expert
Level 2:
New Friend:
Answers
87
Questions
0
Helped
30343
Points
209
5 Related Answers
Anonymous
  • 5911 Answers
  • Posted on Aug 04, 2007
SOURCE: How to clean inlet filters?
I don't think inlet filters are going to solve your problem. Does the machine fill normally? If not, this was probably caused by mineral deposits and not the dirty rugs. It may just be a coincidence that a fill problem occurred at the same time. The inlet screens are located in the fill valves. You would have to shut the water supply off and disconnect the hoses to see them. There is a small screen inside each water inlet on the back of the washer. Washing heavily soiled items would not have anything to do with clogging the inlet lines. Now...if you overdid it with some heavy duty items like rugs, it would be reasonable to suspect that you may have clogged the pumps. I believe there are two pumps on the Oasis. One is a drain pump, and I think the other one is a recirc pump. You shouldn't have to open the top of the machine to get to them. The pumps can both be accessed by tilting the machine back and looking UNDER the washer. As you are looking from the front of the washer, the drain pump will be in the right rear of the machine and the recirc pump will be in the left rear. If you wish to check them, follow these steps: 1. Unplug washer. 2. Drain as much water as you can through the drain hose by using a shop vac. If the drain pump is clogged, this may not be possible. Or, it may take a little extra time. Otherwise, you may have a mess of water when you disconnect the hoses. 3. Disconnect hoses from pump(s) and look for any obstructions. You will have to tilt the machine backwards to accomplish this. You also will need to pull the machine away from the wall far enough so it will rest against the wall when you lean it back. Or, get the assistance of another person to help hold the machine back. 4. Carefully, disconnect wire harness from pump and remove mounting bolts. Remove each pump and look inside the impeller section. This is where dirt, sand and foreign objects generally get lodged. 5. Reinstall following the reverse order of the steps described. Now...if you go through all these measures and don't find anything, there is a filter in the wash tub under the inner basket. Cleaning this would require the removal of the nunator (agitator), tub ring and inner basket to get to. I can explain the steps to you if you like, but I don't know if this is something you would want to try to attempt. Cleaning the pumps and hoses is one ting, but removing the wash basket and other components can be a bit involved. Check the pumps first and let me know if you need further assistance. I hope this helps you.
Anastasio Benjou
  • 99 Answers
  • Posted on Jan 27, 2008
SOURCE: roper washing machine mod# RAS8245EQ1
The problem is one of two parts. One is your water temperature switch or your hot water solinoid. To get to the back you must remove the hex screws on the back and then the panel is removeable.
Anonymous
  • 26 Answers
  • Posted on Oct 08, 2008
SOURCE: inlet/ drain light keeps flashing
You have a leak and the bottom pan is full of water. You can remove the cover at the bottom front of the dishwasher and see if the bottom pan is filled with water.
Anonymous
  • Posted on Jul 05, 2009
SOURCE: how do i put it back together?
Here are some pictures that helped me reassemable my powershot 5700 back together.
vette007
Anonymous
  • 132 Answers
  • Posted on Jul 12, 2009
SOURCE: MIELE NOVOTRONIC W939
IF YOUR PROBLEM STILL THERE DONOT TRY TO PLAY WITH INLET BECAUSE IT HAS ABIG WATER PRESSUR CAN HIRT
THANKS
Haier hlp21n washer valve inlet - Water is not coming properly very less water then usual
Hi, if you turn off water to machine, remove flexable feed pipe to it and look into inlet hole, you should see a filter, this should pull out, maybe with plyers carefully, if blocked, clean with bleach, or descaler, ours (on a bosh machine, is in the actual tap on the wall, most odd that.) & replace.
If this is the cause, I would do it maybe every 6 months or yearly, depends on age of machine.
Hope this helps.
2helpful
2answers
2helpful
2answers
Leaking water from the hose connections
Had the same problem w/the water inlet w/initial installation. When the water inlet was hooked to the faucet and into the washer, water leaked on the washer end. The manual tells you to put a new "flat" washer (provided) in the washer machine water inlet, but water still leaked. It's actually the not flat washer, it's more of an "U" shape washer that goes into the washer machine water inlet and fits right over the filter in the water inlet valve. Leak was solved, but faucet was on and water was not filling in the drum. Turn power on, select cycle, water level, and press start and water should start filling the drum.
Error code E10
Did you check the water inlet screens?
Remove the fill hoses and take a look at the screen in the water valve to make sure they are clean.
First you have to take the two screws in the back that are contected to the cover part of the washer out. Pull the back of the of the cover towards you and lift it off. You will see three multicolored wires connected to the inlet housing that you have to remove so with out saying make sure the washer is unplugged. Next remove the two screws on the inlet housing with out dropping them like I did. Then pull the housing from the detergent cabinet then back towards it to remove the entire inlet unit. You have to work with it a while to get it at the right angle. That about sums it up and to put it back together just do the exact opposite.
Water inlet valve swap
It all depends on your skillset.
Here's what is involved...
Removing 2 screws on the control panel.
Removing the outer shell.
Tipping the washer on its back.
Removing 2 spring hose clamps.
Couple more screws.
Unplug wire harness.
Put back together.
It may take you DAYS to do it (waiting on parts and/or causing other damage because you dont know what you're doing etc..) - where as a tech will have it done in a couple hours.
If it sounds withing your scope go for it!
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
2answers
Haier XQB55-10 : water leakage from inlet hose jointer
You must examine your machine hose to see if it is blocked. Clean out the fine nets in the hose as well as at the machine entry (inlet water entry). Clean well with a tooth brush, refit carefully. Water should be in good pressure for machine operation.
5helpful
2answers
Haier HWD1000 washer/dryer
solved!!!! theres a flaw in the machine, lint builds up in air return area from the back of the machine to the heater, takes about 45 min to fix, take off lid and back pannel, remove weight, remove heater wires and hoses, remove plastic air return area, clean out lint, put back together, the air temp sensor is in the plasic housing in the rear of the plastic housing, the lint blocks air from circulating and triggers warning
Water wont stop
With these symptoms, there is only one culprit, the inlet valve is stuck or there is trash inside the valve body holding the seals open. You have removed all other possible culprits by unplugging the machine.
You have two options:
1) Replace the inlet valve.
2) Sometimes you can take the valve apart carefully and clean it out and put it back together and it will solve the problem.
The valve is not hard to take apart, you just have to observe and remember where everything goes.
Top Haier Washing Machines Experts
ZJ Limited
ZJ Limited
Paul Carew
Are you a Haier Washing Machine Expert? Answer questions, earn points and help others
