Question about LG Televison & Video
I have an LG LED TV 55LB5900-UV which has its backlights flashing off and on at say a 1 hertz rate.
I'm an engineer and have measured the voltages from the PS board to the LEDs and have swapped the PS board with another and got the same results. I now have the TV full apart and see that most of the LEDs turn on, but not all of them. The LEDs that do not light are scattered amongst working ones. I do not see a series of LEDs in a line out. Is the failure mode such that the LEDs work reasonably well until too many fail and then the remaining start flashing? Or is it some other control that has failed? Regards, Richard
SOURCE:
  • 4234 Answers
SOURCE: display Backlight failure - Philips MC235
Most likely there is a bad connection either at the display itself or in the power supply. If you are comfortable working with this equipment and can solder, try resoldering the pins for the display itself first.
Keep us posted.
Dan
Posted on May 28, 2008
MrScary66613
  • 1990 Answers
SOURCE: inoperative LCD TV
Welcome to Fixya! My Name is Travis! I have heard this Problem Before on Another Model. Turns out it was the Power Switch in that case. Yours has the Exact same Symptoms. Get that Checked and let me Know so we can go Further or if that is it.
Posted on Jan 02, 2009
heatman101
  • 43501 Answers
SOURCE: IM350 when battery inserted flashes green then
Check the battery contacts in the gun...
Here is a tip that I wrote about the Paslode nailers and the problems that can come up with them.
I also have a link to the Paslode manuals which contain Paslode cleaning and troubleshooting guides.
If you need parts for your Paslode, there also is a link for a site that sells the Paslode nailer parts.
Paslode Cordless Nailer Problems
heatman101
Posted on Mar 06, 2011
  • 6771 Answers
SOURCE: If a warning light indicates the CPU is not functioning, does that mean I have to get a new processor?
Yes! judging by all the cascade break downs, I would suggest replacing the motherboard, HP has a history with motherboard issues.
Posted on Mar 29, 2012
Testimonial: "devastating but useful"
SOURCE: Viizio VT420M has scrambled Display, Sound, Backlight and PS outputs are all there
I would suspect the main board as well
Posted on Oct 03, 2012
Hi there.I have an lg led tv model 42LB5800 with no picture just sound. Also I can see the image with the torchlight. How can I fix it? thanks
The back light driver is bad. You could have lost the voltage from the power supply board to the led driver too. If you have a volt meter measure all the voltages on the power supply. The correct voltages are printed on the board next to the connector that goes to the rest of the TV. If they are all correct then the backlight driver is bad. You can get parts from here: TV Parts Universal TV Stands DLP Chips ShopJimmy
Aug 18, 2018 | LG Televison & Video
LG TV 39LN5300 - What is normal voltage at LED connection to power supply?
ok so the problem is not with the power suppkly it is with the leds inside the panel they are in strings and usually only a few of them are your problem see the link for led prices http://www.shopjimmy.com/auo-t390hvn02-2-led-strips-8-strips.htm
Feb 16, 2018 | LG Televison & Video
LG 42LN5400-UA.BUSYLHR back lights not working, sound working, flashlight test shows video working.
This is a common problem for LG 42LN5xxx & 47LN5xxx LED TVs, the problem is defective LED back lights strips, it has nothing to do with main power supply & the main board.
Aug 31, 2017 | LG Televison & Video
Black Screen on LG LED TV. From what I can see, I have not backlight, but I have sound and I can see the picture with a flashlight...TV flashes on start up. Is the LED panel or the T-conn board ??.
LED backlight of your TV might gone. If you are a good service technician and know about electronic repair, check LED Driver voltage, if voltages are normal then you can test your LED backlight by applying external voltage to the LED backlight to reconfirm. Link to download Service Manual: https://www.scribd.com/doc/159016486/LGE-47LV4400-Service-Manual-R01-1 LGE 47LV4400 Service Manual R01 1
Mar 31, 2017 | LG Computers & Internet
LED television is flickering what is wrong?
Flickering can be adjusted. In rare cases, power board inside it might need replacement. If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
Jan 21, 2017 | LG Televison & Video
Samsung monitor 2232bw plus backlight fade in black backgrounds scenes
Most common failures in these LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply C242 470uF 10V, C241 & C242 1000uF 16V, C261 & C319 680uF 35V failed as indicated in the attached picture, replace them at once.
If the power supply board is working then it is back light problem, first do a flash light test. If you can see the image in the flash light test, follow the steps how to test back light voltages: https://how-to-repair.org/repair/lg-tv-repair-manual-pdf/lg-led-tv-no-backlights-32ln5300-32ln5310-32ln5700-voltage-test-troub/2pyuXwNkBMA.html and follow the steps how to repair back light LEDs: https://www.youtube.com/watch?v=_poWTEihIJU Fix Led Backlights for TV or Monitor Lg Led Tv No Backlights 32ln5300 32ln5310 32ln5700 Voltage Test Troub Lg... Fix Led Backlights for TV or Monitor
samsung-2033sw-2233sw-ip-43135a-bn4400124s-power-board-dfydxumns33ohqc3bsmt22yf-3-0.jpg
Nov 07, 2013 | Samsung SyncMaster 2233BW 22" LCD Monitor
Open Questions:
Televison & Video Logo
105 people viewed this question
Ekse
