Lift the head two pedal clicks off the carpet.
Lift the headlight and you will find a silver thumb dial to remove the carpet head. At the front of the head there is a square dial which you must rotate to release the belt if not broken. Rotate the square dial , then release the silver thumb dial under the light housing and the head will detach.
Flip it upside down to expose the brush and open the grate covering the brush. Note on either end there are colored leveling blocks for the brush. Reinstall with same colors showing.
Clean any hair and thread from the brush roll and insert new genuine belt. reinstall in opposite order, Be sure to turn the square dial backward to align the belt in a twist pattern before reinstalling the head onto the vac.Then lower onto carpet with pedal.
