Posted on Sep 14, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hello I have a ricoh 2027sp aficio that is getting a sc819 error message Can you help
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Oct 25, 2009
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
3141
Points
Anonymous
Level 2:
Guru:
  • Expert 389 Answers
  • Posted on Sep 14, 2009
Anonymous
Expert
Level 2:
Guru:
Answers
389
Questions
Helped
182329
Points
845
Hi! I'm Sergey.
Mistakes of the controller
These mistakes are flashed right after cut-in or after POST
RICOH 2027sp Afico
Code Description Required action
640 Errors relationship with Engine board to Check join If error is often repeated - change Engine board or controller
641 Errors relationship with Engine board (no answer) Check join between controller and Engine board
819 Errors CPU controller If error is often repeated - change controller 821 Errors CPU and timer ASIC Switch off and include devict If error is often repeated - change controller
822 Errors HDD timeout to Check join HDD with controller to Change HDD
823 Errors of the test NIB (board of the network interface) Switch off and include device to Check join NIB with controller to Change NIB
824 Errors NVRAM to Change NVRAM 827 Errors SDRAM to Change controller 828 Errors Flash ROM
829 Errors additional RAM to Check join to Change additional RAM
835 Errors of the parallel interface If error is often repeated - change controller
836 Errors ROM font are Not used in given models
837 Errors additional ROM font
838 Errors of the pulsing generator If error is often repeated - change controller
850 Errors of the interface NIB 851 Errors of the interface IEEE1394 # 860 Errors of the start HDD Switch off and include device to Check join HDD with controller to Change HDD
862 Damaged кластеры on HDD If error is often repeated - change HDD
863 Impossible read given with HDD
864 Errors of the access to given on HDD
865 Errors of the access to HDD
900 Errors of the counter of the controller If error is often repeated - change NVRAM 99 Errors of the renovation of software Try to load ON once again
Sorry(( It's all i can do for you. Do not warry. Best regard!
Anonymous
Level 2:
  • Expert 162 Answers
Anonymous
Expert
Level 2:
Answers
162
Questions
Helped
130996
Points
285
819 Kernel mismatch error
Software bug
Download controller firmware again.
Try press . (point) and # Both simultaneously more of 10 sec this reset and reload the software. The copy can be print a Report of error.
2answers
J'ai une ricoh mp c5501qu iaffiche sc819
North American website, we speak English :>)
I have a ricoh mp c5501 which displays sc819
Google Translate ici.
https://translate.google.ca/?sl=auto&tl=en&text=J%27ai%20une%20ricoh%20mp%20c5501qu%20iaffiche%20sc819&op=translate
The answer is NOT good!
AFICIO MP C551 SC 819 ( 5348 0x5554444F ) - Copytechnet
https://www.copytechnet.com > forums > 126200-aficio...
Jan. 13, 2018 - SC 819 is a fatal kernel error. Either the controller and possibly other boards were blown by the power surge or the components you replaced on ...
Ricoh Aficio 2035 SC819 Error Code - Copytechnet
Mar. 31, 2010
Error Code Ricoh MP5002 SC 819-00 - Copytechnet.com
Apr. 13, 2016
Error Code SC-819 MP 5000 - Copytechnet.com
Oct. 4, 2013
Thread: error SC 819 - Copytechnet.com
Mar. 30, 2017
More results from www.copytechnet.com
SOLVED: What is sc819 for ricoh aficio c4501 - Fixya
https://www.fixya.com > ... > Ricoh
Sep. 1, 2019 - Yeah most likely the Hard Drive, just replace them with off the shelf ones. Could also be the dimms, controller, nvram or firmware. I would unplug the HDD first ...
SOLVED: My machine ricoh mp c2352sp displays SC 819. I
Nov. 18, 2019
SOLVED: My ricoh aficio is showing sc819 - Fixya
Jan. 24, 2018
Ricoh mp 2550 error code sc 819 how to solve this problem
Nov. 21, 2019
SOLVED: Sc819 trouble/error in ricoh aficio mp5000. any - Fixya
Jun. 2, 2011
More results from www.fixya.com
Ricoh Aficio 480W - SC819 - PrintCopy .info
https://printcopy.info > brand=Ricoh > code=SC819
Ricoh Aficio 480W · Code: SC819 · Description: Fatal kernel error. Due to a control error, a RAM overflow occurred during system processing. One of the following ...
#3
teebee1234 teebee1234 is offline
Service Manager
1,000+ Posts
teebee1234's Avatar Join Date
Jul 2008
Location
Northville, MI
Posts
1,669
Rep Power
46
Yeah most likely the Hard Drive, just replace them with off the shelf ones. Could also be the dimms, controller, nvram or firmware. I would unplug the HDD first and try rebooting (clean and reseat the dimms while you're at it). If it boots up ok then replace the HDD. If still the error with the drive disconnected, swap out the memory dimms. Try reloading firmware before replacing any other parts.
Resolve a J011 error - paper jam
Firstly clear the paper jam then reset the printer!
1helpful
2answers
SC819 on Aficio CL1000N printer
SC819 is most likely a memory problem caused by a fault with the RAM or ROM modules in the printer. Replacing the faulty unit is the only remedy, and if it's the ROM, that's not going to be straight forward! Sorry it's not better news.
Service Call SC819
I found that this 'SC 819' occurs if you use the bypass tray for the scanner. I found also that this error can be fixed with an firmware update. See link. http://www.copytechnet.com/forums/showthread.php/32934-Ricoh-Aficio-2035-SC819-Error-Code?p=132762&viewfull=1#post132762
I have no idea how to do that at the moment, and I can't report the success of this way.
SC819 ON A MP201
SC819 ON A MP201 - Ricoh Office Equipment & Supplies. Ricoh Office Equipment &... Ricoh aficio 2022 error code sc542
Ricoh 3010 sc819
processing
Possible Causes
• System program defective
• Controller board defective
• Optional board defective
• Replace controller firmware
Sc819 trouble/error in ricoh aficio mp5000. any help? thank u
SC819: software error. upgrade controller to the latest version. Faulty RAM and ROM DIMMs also cause this problem.
Ricoh Errors
5helpful
2answers
Error Code ''SC441'' on Ricoh MP4000 Copier
The machine have problem with the transfer roller or the motor which drives the transfer is overloaded,
see do the right door is closed good if this not help it will need to be checked by a technician
Top Ricoh Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
