Jura Capresso Impressa S8 Coffee Maker, Espresso Machine Logo
Posted on Sep 13, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
No steam on Capresso Impressa S8
I have 2 Jura Capresso Impressa S8 coffee machines. One is set up to use water filter, the other is not. While changing the water filter, first machine wouldn't complete rinse cycle, appears to not have steam function work- it grinds away, but no steam. I finally just started using it without filter.Next machine quit during decalcify cycle- same problem no steam. Makes me believe there is something defective in design- 2 machines malfunction in same manner.Question is- how to retore steam function which probably is core problem.
Anonymous
Level 2:
  • Expert 143 Answers
  • Posted on Sep 14, 2009
Anonymous
Expert
Level 2:
Answers
143
Questions
0
Helped
70937
Points
280
Most likely problem is over temp cut out switch. Small diode attached to the boiler to prevent damage during boil dry, or fault in the heating element itself. Difficult machines to repair and best handled by a service technician.
Jura impressa s8, the display shows" please wait" and doesn't switch to the Coffee Ready.
This error is because:
1- Flow meter is blocked & not sending signal of water flow.
2- Entire hydraulic system is filled with Calcium deposits and slowed down flow of water.
Solution:
1- Open the machine and manually clean flow meter. It is located between the water tank & the pump.
2- Follow this by manually descaling the machine. Seelink. Do not use automatic descaling method suggested by Jura.
Stop using Filter cartridges as the machine reminders for descaling are silenced by use of filters. Services Unlimited Inc Parts Guru Since 1988
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edward_bbd2c7ff4ee1828a
2helpful
Jura impressa Z5 doesn't switch on anymore. A few days before just was displaying "maintenance" and then no more signs of life.
Search Results
    How to Fix Jura Z5, Z6 and Z7 - YouTube
    ? 16:03
    https://www.youtube.com/watch?v=HlCu5m9isT4
    Aug 18, 2013 - Uploaded by Parts Guru
    I changed the filter, pressing button for System Fill, get message System is filling. .... My Jura Capresso Z5's milk frother doesn'twork. When I ...
    Jura Capresso Z5 Impressa - No milk frothing - YouTube
    ? 1:05
    https://www.youtube.com/watch?v=_jF_8rNUn4A
    Oct 25, 2013 - Uploaded by Frederic Valiquette
    Hi all, My Jura Capresso Z5 Impressa is acting up. The milk frother doesn't work anymore. When I ...
    [PDF]Instructions for Use, Manual JURA IMPRESSA Z5 - Esperanza
    https://www.esperanza.ch/.../download_manual_jura_impressa_z5-gen2_...
    The IMPRESSA Z5 - Generation II Manual. The 'IMPRESSA .... 5 Preparation at the touch of a button. 40 ..... As coffee and coffee specialities are very important to JURA, we have compiled a ...... It doesn't matter whether whole milk or skim.
    My Jura Impressa Xs90 won't switch on and nothing is - Fixya
Jura S7 says fill tank but tank full
The brew unit is damaged and needs to be repaired.
Press steam fill water
You can check the water valve, it may become clogged. But you should not disassemble machine if you are not specialist. Contact Jura service center if your machine still under warranty.
Jura impressa x7 does not rinse and coffee does not come out. I do get steam for froth etc
Jura x7 coffee machines are older models in the coffee machine range. It may simply require a full system clean, using jura cleaning tablets, or more likely a service. Bean to cup machines should really be serviced every year to 18 months depending on usage.
We can put you in touch with a Jura engineer if you need one, contact me here Denby Dale Coffee
Jura Impressa X90 doesn't give water or coffee. Keeps saying: fill system
Hello, make sure the magnet in the water tank moves freely, sometimes it gets stuck with deposits, its a small black rectangle near the base. if its not free, you need to put some descaling solution it the tank to clear it.
1helpful
Jura Impressa S95 recently, the amount of coffee being served is much reduced and water seems to be diverted through the steam outlet
Find a great article on what needs to be done here:
http://www.wholelattelove.com/articles/jura_capresso_cleaning_guide.cfm
I have a Jura S9A that is about 2 years old, brewed about 1600 cups. Regular filter changes/cleanings. When I brew a coffee, it dribbles out, but makes a full cup of coffee. It also has trouble getting a...
It's all plugged with 'lime scale'. That's the white stuff that builds up from hard water. Regular vinegar run through at least two cycles will clear it, then a couple with fresh water to rinse it. That will bring it back to normal flow!
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Top Jura Capresso Coffee Makers & Espresso Machines Experts
Mike Cairns
Mike Cairns
Sulejman Sulejmani
Sulejman Sulejmani
Grand Canyon Tech
Grand Canyon Tech
Are you a Jura Capresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
