How to save Word as PDF
<p><span>Many people have to deal with PDF format every day. Business professionals, knowledge workers or even students, they need to create PDF file for some reasons but since Adobe Acrobat will cost thousands of dollars, knowing<b> <a href="http://www.advancedpdfconverter.com/products/wordtopdf.html">how to save word as PDF</a></b> is veryusl in our daily work..</span><br />
<p><span> </SPAN><br>
<p><span>How can you save Word as PDF? There are several methods for you. It depends on which Word version you are using.</SPAN><br>
<p><b><span>Using Word 2007 Add-in</SPAN></B><br>
<p><span>If you are using Microsoft Office 2007, you can download the add-in.The plug-in will automatically add the <b>Save as PDF</b> function into your Office 2007 programs. So that saves the documents directly to PDF Format.</SPAN><br>
<p><span>Click on the Office icon on the top left corner, then click "<b>Save As</b>" on the drop down menu and then select "<b>PDF</b>". The Word document will be saved as PDF.</SPAN><br>
<p><b><span> </SPAN></B><br>
<p><b><span>Using free Online Conversion</SPAN></B><br>
<p><span>If you are using Microsoft Office 2003, you can use free online conversion.Google a free online conversion and choose a good one</SPAN><br>
<p><span>Click ' Browse' and select the file on your computer, Click 'Convert to PDF' and wait for it to process. And then you can open it in PDF format. Some free online conversion require you provides Email so that they can email the pdf file to you after conversion.</SPAN><br>
<p><b><span>Using Desktop Word To PDF Converter</SPAN></B><br>
<p><span>Although online Word to PDF Converter is easy to use and most are free. But when we nee to convert confidential files or your own works, due to privacy, we cannot trust online converter.Also if you want to convert large files, online conversion may results failure. So the best way is uing a desktop PDF Converter like <b>Advanced Word To PDF 5.0</B> which provides you a safe and professional method to convert Word to PDF quickly.</SPAN><br>
<p><span>The conversion quality of<b><a href="http://www.advancedpdfconverter.com/"> PDF to Word Converter</A></B> is fairly good, all the original text content, page layouts, images,and text hyperlinks preserved after conversion.It allow you convert large file at the same time.</SPAN><br>
<p><span>What is more, The PDF files created by Advanced Word to PDF are protected with strong 128bit encryption. Therefore, your PDF documents could be protected by Owner Password, User Password and more advanced features to against from copying text and images, modification to document and comments, printing document, etc.</SPAN><br>
<p><span>Download the program and install it. And then add your files to convert. Of course you can Specify output folder like location and Advanced Option such as add password , copy,edit limitation etc.</SPAN><br>
<p><span>The process is easy and takes a few minutes even you are converting large files.</SPAN><br>
<p><span>The three method post above shows you how to save word as PDF , you may have your own choice when you need to<b> <a href="http://www.advancedpdfconverter.com/products/wordtopdf.html">convert word to PDF </A></B>files.</SPAN>
