According to Nintendo u can try this. 1. push the reset button and if that doesn't work unplug all cords and memory cards (including sd) from wii and unplug av from the wii and the outlet in wall. Wait 2-3 min and then plug it back in. Thats as far as i got because that fixed my problem hope this helps someone!!!
SOURCE: eee pc won't turn on (I think have already posted this,not sure)
Sounds like a classic case of hardware failure!!!!!!! possibly your motherboard, start by removing the battery, hard drive and optical drive.
disconnect the laptop monitor and connect the laptop to an external monitor.
remove the memory modules clean the brass contacts with a eraser and place back in the machine 1 at a time to check to see if they work, remember to plug in the AC power suppy, if you see the post screen then its a memory issue and you can then reconnect your laptop monitor to see if it lights up, if everything works but the monitor then its the inverter or backlight that has blown and is easily repairable saving you money on a brand new screen
SOURCE: Power issue with Olevia LT23
this is bull do...The same thing happens with my TV I Have the Olevia 23" and the power will not turn on.
$700 shot, who cares about the rebate when it works on a short while...
SOURCE: Power on problem for My Syntax Olevia LCD TV 23"
I have a 24" Olevia LCD TV. Same symptoms (Stdby LED is on, press power and it flashes off, then back on). The USB cable to the Service Port also worked. But being of sound technical mind, I figured this means that the PC is supplying the +5v to the circuit. What I did was disassebled the TV, carefully disconnected all the cables, and opened it up to reveal the circuitry. I looked over the circuit and noticed the 1000uf/16v capacitor at position CS21 was failed and bulging. I removed the cap, tested it and verified that it was indeed failed. I went to a local Radio Shack and picked up a 1000uf/35v electrolytic, after all, the value is what mainly matters as long as it's not lower voltage than the original. I replaced the new CS21 capacitor back in the circuit (it is polarity sensitive, so pay attention to what the original mounting position is). I reassembled the TV and Viola! Works! No need for the USB cable to the Service Port!
I hope this helps someone!
-Matt
SOURCE: INSIGNIA LCD won't turn on
replace 2 condensers in the power supply with greater voltage ones.original are 1000uf 35volt...use 1000uf 65volt...99cents each
power circuit is made to fail with typical tv industry tactics...the warranty is reflected by the life of their condensors (capacitors) average life is 2000 hours..
easy...huh
if your a smoker...you must clean the button cover as they get stuck on with your stupid tobacco residue. 75% of all LCD tv's that smokers own fail this way...
\tough huh?
TRY TO STOP SMOKING...
