Hello Carlos, check the power outlet, which does not have false contacts, test the socket, connecting a lamp and check that it does not turn off
If you try and it's ok, then, the problem may be in the TV connector cable
If it is an Interlook, replace it with an equal one
If the cable comes from inside the TV, then connect it and start testing where the false contact can be
For this test, wear insulating gloves
Hope you can solve the problem, comment
Regards Franco Dosil
Hola Carlos, revisa el toma corriente, que no tenga falso contactos, prueba el toma, conectando una lampara y controla que no se apague
Si pruebas y esta bien, entonces, el problema puede estar en el cable conector del TV
Si es un Interlook, reemplazalo por uno igual
Si el cable sale de dentro del TV, entonces conecta lo y comienza a probar donde puede estar el falso contacto
Para esta prueba, usa guantes aislantes
Espero que puedas solucionar el problema, comenta
Saludos Franco Dosil
SOURCE: Lost power cord
Should be OK as long as it's capable of carrying the wattage the system is pulling. The TH-42PX60U is rated at 320 watts max - you should be OK as most computer cables are rated well above that. However if you're worried, us the power cord from a laser printer or copy machine - it will definately carry the load.
