SOURCE: CHANGE JAPANESE TO ENGLISH INSTRUCTIONS
most of the nv-gs50 cannot support multi-language (i.e. the ones manu/bought in japan).
you may be able to find a firmware update, but i would not recommend it---i.e. you are stuck with japanese
SOURCE: Change language on command to english
I varied the sequence with the command buttons until the option came up english or japanese where I punched in English.
SOURCE: how to change os from japanese to english
You can try first to go to your Control Panel and to REgional Settings and change your language to English. If that doesn't work you will need to resintall the Operating System and select "English". When you put the CD in you will be prompted to reinstall or repair. Depending on your OS, you can try repair and then you should go through the prompts to select English.
SOURCE: changing language from japanese to english
i have a panasonic CN-HDS955 car stereo and it is in japaneses and i want to change it to english
SOURCE: Sonic Secret Rings Wii~Change from Japanese to ENGLISH?
Ok, i just figured this same problem out. When you get to the main screen press 2 then you should have 4 options to choose. Pick the bottom right one. After doing this you will have to pick the top selection then the 2nd one in the little box, this will switch the text language. Have a good day.
