i suggest first reading the directions to make sure you are connecting the face plate correctly. or you could gorilla glue it on just to make sure the connections from the face plate and radio are connected before binding the two
Kd-bt1 sucks You can pair 20 times the you need at new reciver. it can not keep the pairing in the system.. there are no solution on this problem...says JVC....
This is more likely a problem with the CD player, not the receiver. The CD player has what are called "muting" transistors that should prevent the creation of the "pop". Try the CD on another system. I suspect that the pop will follow the CD player. If this is the case, close this question as "solved" and post a the make and model of the CD player requesting a fix for a muting transistor problem.
I received a reply promptly from JVC to check power connections for shorts. O course I had already done that. So as a last resort, I pushed the power switch on and held it for maybe 10 seconds. It seems to have reset the unit, and it's playing fine. Best of luck, hope you all read this and it works for y'all. AJ
sounds like a popped power capacitor, its going to have to go to the shop most likely around 100.00 repair. taking the back off yearly and airdusting them helps, especially if you have a smoker in the house. caution high voltage present even when off, the heavy single red wire going to the tube is high voltage be careful.
disconnecting the tv from the audio connections on your amp may have created a powersurge in the audio input selector IC. Try powering down the amp at the wall completely for 5 mins and turn it on again. Check to see if operation has returned. If not then it may need an audio selector chip replaced.
This problem can be caused when connecting or disconnecting rca connectors from non earthed equipment like TV and VCRs, By the nature of this type of connector, it will spike the input line by connecting with voltages floating often over 100volts.
to avert this problem occurring, wire all the equipment up and with aerial disconnected and tv / vcr turned off at the wall socket. Turn the equipment power on at the wall last thing.
