SOURCE: where to buy in los angeles replacement bulb ryobi drill/flashlit
Try King Power ph#323-262-3517 or Minit ph#323-264-7006. You might also try some of the bigger box stores or lumber yards Hope this helps I am on the east coast
SOURCE: Very little juice in freshly charged batteries
have you tried the batterys in any other tool?
you would also need to check the voltage of the batterys they should be at least 18 volts (19 prefered)
then if the batterys do not show charged you would need to make sure the battery charger is putting out voltage.
After that contact your closest Ryobi service center we would check that for free to let you know what you need, I am sure you local place would do the same.
SOURCE: ryobi spare parts
Unless you have the part in hand, which you could take to a specialized machinery or spring supplier to see if they could match it up, the only other way to get the correct part is to contact ryobi direct and talk to their parts department. They will be able to tell you the part number, and if available, send you one out direct from their warehouses.
Good Luck!
Testimonial: "Thank you very much for taking time to help! I have phoned Bunnings who I think are now the only suppliers of Ryobi in AU who are sending a spare. "
SOURCE: my ryobi 14.4v cordless drill won't turn on. The
use
AC / DC Power Adapter Replaces Ryobi One+ Batteryhttp://lcdpayless.com/ryobi_one_power_adapter.php
SOURCE: Compatability issues with new Ryobi Lithium Ion Batteries
i have the same problem and have returned once for replacement charger and battery, still no working well help [email protected]
thanks
