Televison & Video Logo
Tom Stckel Posted on Sep 08, 2019
Looking for backlight strips for my philips model no. 40PFL3107H/12 AND INVERTER TO
jesus vazquez
Level 1:
New Friend:
  • Contributor 4 Answers
  • Posted on Sep 08, 2019
jesus vazquez
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
333
Points
12
Reepende a donde vivas si vives en mexico las venden en mercado libre si vives en otro pais em EBAY o en tiendas de electronica y en tu localidad en un desguesadero de electronica si eres usuario mejor lleva tu pantalla con un especialista,y si eres tecnico consigelas en donde ya mencione.
5 Related Answers
Anonymous
  • 3 Answers
  • Posted on Oct 19, 2008
SOURCE: Backlight inverter
A backlight inverter is the power supply to power the lamp or lamps in an LCD display, so when you look through the LCD there is a souce of light behind it. Kind of like holding a peice of paper up to a light and looking through it, The light from behind shines through the paper or in your case the LCD display. You would have to open up the LCD case in order to find what is usually a long thin board, similar to the one below. This may need to be replaced or you may get lucking and just be able to replace the F1 (fuse) component and fix it. (or have a techical friend do it for you)
Anonymous
  • 71 Answers
  • Posted on Dec 09, 2009
SOURCE: Replacement Backlight inverter
ebay may be a good place to look?
Anonymous
  • 14 Answers
  • Posted on Mar 21, 2011
SOURCE: I have a Philips 42PFL7422D
There are only two boards. Master - 6632L-0470A REV 1.3 and Slave - 6632L-0471A Rev 1.3
Anonymous
  • 32281 Answers
  • Posted on Dec 03, 2011
SOURCE: Backlight inverter board problem for Philips 30PF9946 30 in. HDTV-Ready Plasma Television Cost
You may be able to get an inverter board from this WEB site.
LCD screens and Inverterswww.lcdparts.net
gewiz
Rob Hill
  • 1480 Answers
  • Posted on Jul 15, 2015
SOURCE: have 12 and 24 volts going to the inverter, however, there is not any voltage at the backlight area.
hi the inverter will have some kind of step-up transformer for the backlight driver, now you need to be really careful because high voltages are involved... so beware.. capacitors holding a charge can kill.
Look for a invertor replacement board for the LED ?? or what ever it is however make sure the screen is not damaged in any way otherwise you be wasting your money..
Regards
Rob
www.gewizrepairs.co.uk.
1helpful
2answers
Need assistance diagnosing a problem with a Samsung UN75AU8000 LCD TV
Lets start by eliminating the parts that won't cause your issue, the main board could not cause it, it turns the lamps off, that's correct it turns them off, the inverter will turn the lamps on with the main board not connected. The power board could cause it but it's not probable, only way this could happen would be some shorted windings in the transformer that powers the backlights and in the thousands of?? set's we've repaired in our shop I've only seen excessive backlight voltage a couple times. Considering this set is edge-lite, the lamps get quite warm, if a few are shorted the strip will get hot enough to melt the plexiglass. Where are you getting the replacement lamps from? Is it possible they're not meant for the model set you have? Are you getting a good contact with the tape on the back of the strips? They need to be tight against the frame, is there tape that's bunched up causing a gap between the strips and frame? Without pulling up service lit on the TV (not at shop now) I can't tell you what the correct B+ voltage should be coming out of the inverter but usually it's about 80% of the DC rating of the caps. Other than what I've suggested I can' think of anything else to advise on, I can get the exact voltage of the inverter next week when I get into work.
50 inch element tv no backlight. checked led strips, they seem to be working fine....whats next?
The next step would be to check the inverter board. This board is responsible for supplying the power to the backlight. If the inverter board is defective, it will need to be replaced. If the inverter board is not the issue, then the issue may be with the mainboard.
I have a large darker than the rest of the screen on my vizio tv
The Vizio "E" (economy) series sets have local diming, on most brands if some of the lamps go bad the screen is black but not on these model Vizio TV's, for this reason it's harder to troubleshoot the set for possible bad backlights or backlight inverter issues. If you have a LED backlight tester you can test each zone at the backlight connector off the inverter board to see if each is working, without a tester you're going to need to remove the panel then move strips that don't light to ones that do and see if it's the strips bad or inverter issues.
We have an LG tv that has sound but no picture. I thought it needed a backlight inverter but parts co. said the model was LED & doesn't have an inverter. So what's wrong.
most likely the problem is if your lg tv is between 40 and 50 inches that the internal LEDS have gone bad typical with LG models you need to replace the LED light strips inside the panel and it is not easy to do unless your experienced with this take it to a shop or see the link below for more info LG 39 LED TV Model 39LN No Backlights Bad LEDs How To Replace LED Strips
I have a 47" Philips LCD TV Oct 2008 Model # 47PFL3603D/F7 When I turn it on, it works fine for about an hour or so. Then the screen goes black, not a fade right to black. Sound is still on.
The backlight inverter is built into the power supply of this unit. When it fades to black screen, do you see any backlight at all?
If you do see some light, you have a 'blank screen' problem and the backlight is not the cause. Since you can still hear sound and can control the tv otherwise, the problem is likely in the TCON board.
If there is no light coming out, perform a flashlight test (search YouTube for details on this). If you pass the flashlight test, then try replacing the power supply board.
3answers
HOW CAN I REPAIR A PHILIPS 42INCH TV WITH NO BACKLIGHT
Providing it is backlit and not oled or other The inverters hold the backlight in each and can be obtained via eBay for most make and models.best to put the screen on a folded blanket on the floor before attempting to remove back.make sure the power is off and that you don't touch internals.then inspect each invertor count the number for the screen best to replace all together or you will get uneven illumination.
1helpful
2answers
My magnavox 15in hdtv powers on but the screen is black
Verify that you do have 12~18vdc feeding the backlight inverter board. Look inside the TV for burnt parts, bad capacitors, etc.
http://en.wikipedia.org/wiki/Capacitor_plague
2helpful
Sound on, picture not on
If the screen is black: Check the backlight circuit, bulb and inverter.
If the inverter and backlight is OK: look at the electrolytic capacitors (round aluminium "cans" with X's or K's on top) if there are any that look "domed up" (swelled), replace.
You've now covered 90%+ of possibilties.
GL!
Top Philips Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
