SOURCE: AIR HISSING NOISE COMING THROUGH DOORS CHROME TRIM.
Trim generally does not have much to do with body sealing. Check to make sure that the rubber door seals are intact and are actually touching the door frame. Make sure your door is properly aligned in the frame. Sometimes the hinges wear and cause some drooping. If condition is not severe, sometimes you can "fatten up" the door gasket by sliding a length of rubber hose inside it. As far as trim goes, most trim on Jeeps is glued on.
Good Luck
