Gloria Watson Posted on Sep 07, 2019
Installed new color cartridages in Kodak ESP 3250 printer. Trying to print a recipe the picture was ok, the printing was not readable. Y
1 Related Answer
E Tipton
  • 4 Answers
  • Posted on Nov 20, 2012
SOURCE: Kodak ESP 3250 won't print black. Changed
I fixed my ESP 3250 print problems by removing the cartridges and print head. Using a Q-tip and warm water, added drops of water to each of the print head ink wells until the water / ink from the wells bled thru onto a cleanex. Did this several times. Dryed the print head fairly well. Then added a drop of water to each cartridge for each color. Reasembled and ran an alignment and to my surprise, it works! I hadn't used my printer in a while, so the ink had dryed on the felt for both the print head and cartridges.......
3helpful
I have an all-in-one Kodak ESP 3250 printer. Bought it 4 months ago. I'm interested in printing only in black, but now the color cartridge has emptied and it won't let me print with the black cartridge...
The KODAK All-in-One Printer uses an advanced built-in printhead. The system is designed to provide excellent image and text quality, while eliminating the need to purchase new printheads every time you replace ink cartridges, and saving you money. The printing system requires that both the black and color ink cartridges be installed to print. If either cartridge is not installed or is out of ink, the printer or printhead will not print correctly.
Install the color a new cartridge, avoid damage to the print head.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
3helpful
2answers
I have a brand new Kodak ESP 3250. Not one drop of ink color or black, is coming out of the cartridge. And even so, the indicator shows a loss of ink. ! no spills inside. I am absolutely certain the...
Clean the gold section of the print cartridge's with a wet paper towel.
Also clean the gold surfaces where the cartridge meets the printer.
Wipe the contacts clean with a dry paper towel once you get no ink back on the wet paper towels. Allow about an hour for the printer to dry.
Reinstall the cartridges and try printing.
Hope This Helps.
Zeppelinx12
I just connected a new printer. I installed the cable from the computer to the printer and plug in the cord for the printer. When I try to print there is a sign that says there is no communication with...
You did not mention installing the Kodak printer driver.
If you have not don so then install the printer driver and then do a test print.
If the test print prints OK then your printer is ready to work.
1helpful
Kodak esp 3250 printer applemac 10.6 os airport express. printer tries to print but no print appears on paper
Sounds like print head needs replacing, try the troubleshooting guide on Kodak website, appears to be a common problem with these Kodak printers, if new it should be covered under warrenty although if not they are expensive
4helpful
2answers
Purchased Kodak ESP 3250 yesterday. Not printing photographs.
Yes sounds to me like one of your ink cartridge is empty. Replace and try again.
10helpful
2answers
Kodak esp 3250 won't print black. Changed cartridge and still won't print black. Just installed new printer.
3answers
The black ink will not print, new cartridge, is spotty and not readable, barely prints black, printing color documents OK
I am having this problem too! prints color but not black, brand new cartridge, sorry I am no help, but looking for help myself!
Top Kodak Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
