What equipment or service?
Hola Maeve Dempsey, indique la marca, modelo y tipo de equipo que est? comentando, para encontrar la mejor soluci?n posible
Espero su respuesta
Saludos Franco Dosil
Hola Maeve Dempsey, marca indica, modelo y tipo de equipo del que estas comentando, para poder encontrar la mejor soluci?n posible
Espero tu respuesta
SOURCE: Thompson recordable freeview box
It's probably a corrupt file. Probably the first one in your library.
What you need to do is go into the library and quickly delete that file.
You need to press delete and confirm before it has had time to notice the file is corrupt.
I think it's green then blue, might be blue then green. I forget.
BTW, If anyone out there knows how to make use of the USB port on these things, can you let me know?
SOURCE: Dvr not working. Won't record, pause rewind
Try unplugging the unit from the electrical outlet for about five minutes- much longer than required- and try it again. If this fails you will need a service technician to resolve the issue. Thanks for using Fix Ya.
SOURCE: My Thomson Top up TV box will not record. I go to
Sounds to me like your hard drive is full. Do you use the topup tv part of the box? If not, deselect all the topup tv channels. This will free up a significant amount of drive. Failing that, you'll have to delete some of your programs, sorry!
To deselect topup tv channels;
Go into the menu option, Customise Top Up TV Anytime, and de-activate all the selected channels
SOURCE: DVR refuses to rewind or pause live TV or record
ruukasu2005,
If you are still experiencing problems with your 625 receiver performing live DVR functions, try unplugging the receiver for about 10 seconds and plugging back in. This will cause the receiver to reboot and acquire satellite signal. After the picture returns, then try to pause. If it still doesn't work, then we may need to replace the receiver. I hope this helps.
Ray Calo
DISH Network
SOURCE: dvr doesent work
Hi djn Collinswhen your DVR is not allowing you to pause or rewind live TV you will need tounplug the receiver for 10 seconds and allow the receiver to power back up and acquirethe signal. Then you will want to try the functions again and make sure theyare working fully.
