you will need to narrow down where the water is leaking from. under the door...? behind the bottom drain door..? underneath machine..? behind machine..? leaks can be found in many areas.
If you have the capability its probably a leaking seal on the water input line at thetop of the water. Often its a simple hoseclamp that needs tightening. Without looking myself thats the easiest solution. Hope this helps!
if leaking on front unit : check rubber seal front glass door. if it ripped you should change it. If leaking behind unit : check water hose , is it placed properly ? If leaking under unit : call technician to repair it. good luck.
