Backlight inverter board fault.
Contact any service center to get it repaired, or replaced.
This type of fault can't be rectified by a normal user. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/ faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
SOURCE: 47inch toshiba lcd tv (HL167) black picture, but
Best to replace both at the same time . Yes they are easy if you can find the parts.
SOURCE: How do you change a backlight inverter board on a Toshiba 46L5200U TV?
SOURCE: 47' (sic) LED TV, model number m470vse. Why doesn't the backlight work?
Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
In some models of LCD TVS; the backlight inverter and its T'Con board will be a part of the panel itself, and will be a built-in type inside the LCD panel. If so, they can't be replaced. In this case; a panel replacement is the only repair. For some other models, the backlight inverter section circuit will be a part of the main power supply regulator [SMPS]. To such sets, the power supply section circuit too should trouble shoot. Contact any service technician. The circuit will differ with models and versions.
SOURCE: Model 42LN5700. What caused backlight failure?
Backlights do fail, and can be replaced. If the set is more than 5 years old, it could simply be backlight failure.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement.
