SOURCE: Whirlpool Cabrio will not heat up....
there is usually a wire diagram inside the rear panel near the timer.
SOURCE: I have no heat in my dryer. How can I tell if it
check for continuity on the heating elements leads.
SOURCE: Whirlpool Duet Dryer is scorching clothes
there is a sensor in the exhaust line in the dryer, near the motor. this tells the heating element to shut off when it gets to a certain temp, either during reg cycle or if the exhaust gets clogged, it is meant as a safety measure, but it sounds like yours is bad so the heating element never shuts off. it is not an expensive part and easy to replace
SOURCE: NEW Electric Whirlpool Cabrio Steam Dryer; NO HEAT
Check temperature sensor. Check to see if heating element is OK.
SOURCE: whirlpool cabrio steam electric dryer has sensor light on and does not work
have a problem with my cabrio dryer its powered on but when i push start the sense like comes on and does nother whats the problem
