Hello Anonymous, to be able to clean the buttons correctly, you must take them out and put them in Isopropyl Alcohol, so that the internal dirt is softened, with the risk that it may not be completely clean, that you reinstall them and they do not work properly
Suggestion, pay attention to the Techico Service, replace all the buttons
I hope you can solve the problem
Greetings Franco Dosil
Hola Anonymous, para poder limpiar los botones de forma correcta, debes sacarlos y ponerlos en Alcohol Isopropilico, para que se ablande la suciedad interior, con el riesgo de que pueda no quedar totalmente limpio, que los vuelvas a instalar y no te funcionen correctamente
Sugerencia, hacele caso al Servicio Techico, reemplaza todos los botones
Espero que puedas resolver el problema
Saludos Franco Dosil
https://usa.yamaha.com/files/download/other_assets/7/324827/htr-5930_manual.pdf https://elektrotanya.com/yamaha_htr-5930_rx-v359.pdf/download.html
SOURCE: HTR-5930
To get audio from your TV through your AV receiver, please connect stereo audio cables from an available AV input on the rear of your receiver such as D-TV/LD or CBL/Sat. Then refer to your TV owner's manual for more information about audio output to an amplifier. You may have to turn off the internal TV speakers in order to get any output from the TV into the AV receiver.
SOURCE: Sears Kenmore Elite Refrigerator model
need model number even though it says kenmore we need to know the model will tell us the maufacturer but start by checking voltage at the outlet to see if you have proper ground
SOURCE: No video signal on Yamaha HTR 5930
On , HTR-5930, composite inputs are routed only to composite outputs. The same happens to component input. You can't see video from V AUX if your TV is hooked-up on component output. Also, check if you connected correctly GREEN, BLUE AND RED on both receiver and TV SET.
SOURCE: what is the yamaha htr 6050 remote code?
You have to "learn" the IR. Yamaha has discrete on and off commands. which universal remote are you using?
SOURCE: Yamaha amplifier HTR 5930 is not sending sound to
... Incorrect setup; incorrect speaker definition; speaker B selected instead of speaker A.
Testimonial: "Thank you. A simple solution for a non technical person."
