SOURCE: Lenovo S series ideapad will find my dlink router no network addr
Generally if you can see the D-Link then everything is trying to talk. Would have to know if the d-link is new out of the box or is part of an existing setup. If the d-link has been part of the network I would suggest that you don't have the security settings correct. If you right click on the network icon and look at the send received numbers. If received is zero then your problem is you don't have the security key (WEP or other type)) setup. If you are getting recieved numbers you may not have the DHCP setup in the d-link. DHCP assigns the numbers to the computer but the d-link has to have this turned on in some models others it is by default.
If both your laptop and dlink are not new and specifically about a year old then I would also suspect that the dlink has died or is dieing on you. If you have had periods of disconnects or slow jerky network acess then these are signs of the dlink having problems. The wireless part tends to go after a year or so while the wired portion probably still works. When they go they are annoying as they work then they won't and so on.
That is you next step to try is to plug in your laptop direct to the wired connection on the dlink to test if the problem is the wifi portion of the dlink. If it connects your problem is the wifi and you probably will have to replace the unit. Next plug it into the cable modem and see if the problem was in the dlink itself.
SOURCE: Lenovo IdeaPad Y530 - 40512SU screen is dark
Have you installed the Lenovo EnergyCut drivers? Without it, laptop may not work properly and turns extra hot. Try letting it cool down before you try again.
SOURCE: my lenovo Y510 ideapad turns on but the screen
The next tim eit is turned on, try shiniing a bright flashlight directly on the screen.
If you can see anything there then the backlight has burned out on the screen, and will need to be replaced.
If you cant see anything, try hooking up an external monitor to the laptop, if you have a desktop the monitor for it will work for the test..
If the external monitor you hook up will work, then you will have to replace the screen..
( or at a minimum the inverter board, or check that the cables are tight that go to the screen)
SOURCE: Lenovo Ideapad Y510 won't turn on or off
try removing the battery and removing the adaptor press and hold down the power button for 5-10 seconds then let got this will power drain your system board noy turn the system on using the battery only without any adaptors to charge or power the system, try turning the system on if the system turnes on leave it turned on for a couple of hours then conenct your sysem adaptor monitor if the battery light and the battery indicator on the lower right of the screen in windows woll indicate that the system is chargin if it is then I believe everything should be fine the blue indicator is for your system if it is blue then your system is turned on and has power if it turned orange and blnking then the battery will be more likely be almost out of juice or may need charging.
As many as two passwords may be needed for any Lenovo IdeaPad computer: the power-on password (POP) and the supervisor password (SVP). If any of these passwords has been set, a prompt for it appears on the screen whenever the computer is turned on. The computer does not start until the password is entered.
Exception: If only an SVP is installed, the password prompt does not appear when the operating system is booted.
Power-on password
A power-on password (POP) protects the system from being powered on by an unauthorized person. The password must be entered before an operating system can be booted.
Supervisor password
A supervisor password (SVP) protects the system information stored in the BIOS Setup Utility. The user must enter the SVP in order to get access to the BIOS Setup Utility and change the system configuration.
Attention: If the SVP has been forgotten and cannot be made available to the servicer, there is no service procedure to reset the password. The system board must be replaced for a scheduled fee.
Sorry hope this helps a little good luck
