Televison & Video Logo
Priscilla Shingleton Posted on Sep 04, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The door won't open on my Toshiba SD-K220S DVD/VCR combo. Worked fine until I tried to use today. No DVD loaded; door just will not open. Tried unplugging. Remote won't open it either.
Franco Dosil
Level 3:
Top Expert:
  • Toshiba Master 10,542 Answers
  • Posted on Sep 05, 2019
Franco Dosil
Toshiba Master
Level 3:
Top Expert:
Answers
10542
Questions
0
Helped
378787
Points
178965
Hi Priscilla, as you say, it is very feasible that the belt that is responsible for opening the CD tray is stretched
it is not easy to access to release the mechanism
I suggest you consult a specialized technical service
I hope you can solve the problem
Greetings Franco Dosil
Hola Priscilla, por lo que comentas, es muy factible que la correa que se encarga de abrir la bandeja porta CD, se encuentre estirada
no es sencillo acceder para liberar el mecanismo
Te sugiero consultes un servicio tecnico especializado
Espero puedas resolver el problema
Saludos Franco Dosil
https://www.manualslib.com/manual/520425/Toshiba-Sd-K220s.html
5 Related Answers
epik559
Erik Garcia
  • 44 Answers
  • Posted on Nov 25, 2007
SOURCE: DVD door will not open
Turn off the unit, Unplug it. wait 30 seconds. plug it back in. Press the power button on the unit press source so that its on dvd and press eject
Anonymous
  • Posted on Jan 12, 2008
SOURCE: DVD drawer in TV/VCR/DVD combo won't open
There is very likely a code that you can enter with your remote. The trick is finding out what that code is. I have the same problem and get the impression that is should not be so hard to find the code on line, which suggests Emerson does not want us to know it, but would prefer we buy a new tv. I will be contacting a tv repair service to see if they know what the code is.
Anonymous
  • Posted on Mar 30, 2008
SOURCE: DVD Player does not work
General Problems
Player won’t work (locks up)
• Try unplugging the AC power cord and plugging it back in.
• Reset the DVD/VCR: on the front of the unit, press and hold the STANDBY/ON button while you press and hold the STOP button—wait at least 3 seconds
before you release both of the buttons. You’ll need to set up your menu preferences because this Reset Procedure returns the DVD/VCR’s menus to the
factory default settings and also erases the contents of the Disc Library.
Anonymous
  • Posted on Feb 15, 2009
SOURCE: Toshiba DVD VCR Combo will not play DVDs now, only CDs will load
you bought it on ebay?
Anonymous
  • Posted on May 12, 2009
SOURCE: Toshiba md12m1 tv/dvd, original remote needs reprogramming
i have a toshiba tv how do i reprogram it ,evry time the electric goes out the tv goes out to be reprogram and i for got how and do not have i book.
1helpful
2answers
GO VIDEO model 1030....VCR works fine...DVD..nothing happens...door won't even open?
Combo units have this essential flaw--if one half fails you are usually done especially if the DVD side fails.
If Door does not open either a disc is jammed inside the mechanism or the mechanism is out of alignment or damaged.
Good argument against buying these units--DVD individual parts are rarely sold--only (if available) would be the entire DVD unit itself--not cost effective to repair.
DVD players are now real cheap (see some for as little as $20) so if not a simple jammed disc or something like that buy a DVD player.
Sd-v392 claims incorrect disc on most dvd`s
I removed the cover,the dvd unit and cleaned the laser lens with alcohal. The two back screws were loose on the dvd unit. It`s working like new again.
5helpful
2answers
Need missing owner's manual; cannot find on Toshiba's site
The manual can be found here:
http://www.managemyhome.com/mmh/owner_manuals/search?query=Toshiba+SD-V295KU
2answers
General Problems
DVD problem with Toshiba TV/VCR/DVD Model MW24FP1
I've only had mine for 3 years- DVD didn't recognize 2 out of 3 discs or would cut out- started about a year ago. Today the whole picture went out. Just don't make them like they used to
7helpful
Dvd door won't open
Mine just did the same thing about 1/2 hour ago. Found this site and tried advice of gopackgo - worked perfectly!
3helpful
4answers
Toshiba tv/ dvd /won't open
Unplug the TV ...wait 30 seconds then plug back in. Worked fine.
Top Toshiba Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
