It sounds like you have a direct short in your electrical system somewhere in the kitchen. It could be a bad switch or it could be a weak GFI. Either way, you need a qualified electrician to check everything out. It will be money well spent.
You should pay for an electrician rather than try to do it yourself due the dangers of electrical shock or accidental fire.
SOURCE: The fridge keep tripping the
Refigerators should NOT be on GFI-protected circuits. Problems have occasionally been reported when plugging a refrigerator, freezer or other motor-driven appliance into GFI-protected circuits. These appliances generally have a motor that pulls significant startup current. Due to the electrical characteristics of motors, the startup current can look like someone getting electrocuted, causing the protection system to trip. The best remedy is to connect these appliances to a non-GFI outlet. Usually outlets that are expected to serve such appliances will not have GFI's installed.
SOURCE: Short in light fixture and Lutron switch no longer
If the dimmer switch worked for a while after replacing the fixture, it could be that the new fixture has a higher wattage and overloaded the dimmer switch "burning it out".
Dimmer switches are notorious for not living up to their rated wattage, and most will eventually "go bad" even if they are not overloaded.
Charlie
SOURCE: Leviton Dimmer Switch wiring and
I recently purchased a Leviton Dimmer switch which has a brown lead. This switch is to replace 1 of 2, 3 way switches that control the ceiling light in my kitchen. My problem is the new dimmer switch has 4 leads including a brown one which has me confused. I have installed and replaced numerous dimmer switches without difficulty. Please help.
SOURCE: What does the orange light
Has indicator always been ON?
Or did it suddenly turn ON recently?
Usually small indicator lights show that device is working, and has power.
Then when GFCI trips, the light goes off.
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you via e-mail or phone while you work on circuit or any do-it-yourself project.
Fixya is always less expensive than a service call.
