I tested the thermostats on the heating elements and they seem to be working.
SOURCE: Dryer no Heat. New Thermostat Burnt Out.
sounds like you are replacing the hi limit thermostat try replacing it with the cycling thermostat as well
SOURCE: Dryer runs for minutes then stops timer keeps going and going and .....
remove the vent on the dryer that goes to the outside start the dryer if it continues to ru n and not cut off you have a venting problem of the house
if it cuts off after 5 mins with the vent off you have a motor that is going bad
SOURCE: heat cycle stops/goes off
Hi Tony, The next thing I would checnge would be the coils on top the gas valve. The tend to not open after the get hot. This is a very common problem with the newer gas dryers. I hope this helps you. Let me know if I can help you further.
Thanks
Vic
SOURCE: Electrolux dryer error code e61
There is a 'tech sheet' in the back pf the dryer. Unplug machine, Remove the access panel on the back to get to it. Reach in and it should be there. It will tell you how to do a button check. You have to enter a test mode through the buttons.
The E 61 is a stuck button.
Enter function test mode and perform key
stuck closed (active). (button) test to determine which button is at
fault. Carefully free the and perform the test
again. If button is free but the key struck code
still exists, replace electronic control.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
