j
jason kemp Posted on Sep 04, 2019
Anyone tell me why my tecnics sa dv-290 amp gets red hot dont switch off but gets to hot and fan dont switch on till it hits -19 db why when this is to loud
5 Related Answers
Ekse
  • 13435 Answers
  • Posted on Sep 30, 2008
SOURCE: My technics SA-DV 290 is
HAve you tried a dvd lens cleaner?
Anonymous
  • Posted on Nov 09, 2008
SOURCE: technics sl-dv 290
I think your dvd is set to a different region. This might help:
1. Insert disk
2.Wait for 'no play'message
3.Immediately press stop
4.It wi go to chapter review automatically in about 5seconds time u should be able to press play and start the movie
Hope this helps
Miss didi
jomabug76
Josh Whitehead
  • 1148 Answers
  • Posted on May 15, 2009
SOURCE: what are the sockets on the rear of the Tecnics HD350 for
FOR RECIEVING SOUND FROM OTHER SOURCES,,LIKE A CD PLAYER,,,,YOU USE A RCA JACKS
flacooo1
Juan Rivera
  • 172 Answers
  • Posted on Sep 14, 2009
SOURCE: helpppppppp me plzzz
it could be the fan if is not turning at all but if your ps3 fan is turning then it is your video card it can be fixed but only with the right tools I got them
Anonymous
  • 6982 Answers
  • Posted on Sep 08, 2010
SOURCE: Cooling fan relay is getting
That seems to be something of a chronic issue. I have heard that some off-roaders move the relay to another cooler location where there is more air flow by extending the wires. That is likely why Jeep puts it where it is instead of in the power distribution center. If you move it, I'd also consider doing a bit of weather proofing on the connector though or you'd be trading one problem for another.
One good place might be inside the lower part of the air cleaner box. There is always a good clean supply of moving air there whenever the engine is running and plenty of room as well.
I'd also make sure the fan motor isn't drawing too much amperage and that all connectors and grounds are good as all can cause extra resistance in the circuit.
1helpful
My samsung er 290 wont stop printing till roll
system option 21.Key on pgm press 21-RA-1-PO-CASH. Turn you key to reg and press PO. Good luck
Hi! i want to know where i can find color code for the (resistance) on a bord tecnics sa-gx490 the number on the board it' R 440 and R443
I am not sure I understand what you are asking for but if you are asking how to tell what the resistance is on a typical resistor, look at this link. (if you need help understanding how to use it let me know)
http://www.hobby-hour.com/electronics/resistorcalculator.php
Electric conversion for conventional radiator fan
shouldn't be a problem as the fan should only come on when the engine is hot, if you use a temp sensor switch
2answers
My Tchnics Sa-Da10 shuts down on what appears to
Ahh technics. Technics always had overheating problems, trust me. Every since they started, their amps would get so hot they would hurt to touch. The reason the fan is not coming on seams to be something inside the circuit board. I'm sure that technics could fix this. If the fan works out of the receiver, then it must not be the fan. ;P
I would maybe get a computer fan, and just put it on top of the receiver and turn it on, or send it in for fixing. Also, do you have to crank the volume to get the speakers to play at your volume, and does the impeadence match the receiver. Because you may be pushing the receiver too hard.
2answers
Mty tecnics
Maybe the audio amplifier IC are fried
What are the sockets on the rear of the Tecnics HD350 for
2answers
Hvac problems
control board low voltage problem
 Grubhead
Grubhead
SmartAviator
SmartAviator
