Did it work through cable leads.?
Could be an output problem, could be an input problem at the PS3, could be a dicky lead.?
Rule out the 1st 2 by testing another piece of equipment through that lead or into the PS3.
If something else works through the PS3's optical input AND through that optical lead,
then it must be a problem with the optical output on the Denon.?
SOURCE: PS3 setup to Denon AVR 2807 & Samsung LCD
Azahid
Since you are running the to LCD monitor instead of a LCD TV this is where you run into the issue. because the monitor is not setup to pull out the audio from the HDMI connection. So there is a few ways that you maybe able to to this.
The first one is look around at the different output cables out there the PS3. (I just got one so I do not know the accessories that are out for the PS3) This is becoming a common setup so if Sony does not have cable that will split off the audio then a 3rd party group may. I know they have one like that for the XBOX 360.
Another you can try is if your monitor will except an analog connection you may need to go that way. That is how I have my XBOX 360 that is my room connected. I have a RBG HD to VGA connect the VGA input on the monitor and the audio going to my sound card.
The reason why I suggested going analog is that right with our curent technology that if you are run with the 2 formats at the same time you will get audio/video sync issues. So you need to go all analog or all digital.
I hope this helps. Let me know if you have any other questions on this and/or need me to clarify anything.
Issken
SOURCE: Denon AVR 2800 digital hookup to PS3
If your TV has an HDMI input, hook up the PS3 w/an
HDMI cable to the TV. This will give you a high def picture (set up the
PS3 to output the max resolution your TV displays). That will take care
of the video side.
Next hook up an optical cable from the PS3 to the receiver. In the PS3
menu, you have to change the audio settings to output the sound via the
optical cable.
Finally to get sound out of the receiver to the speakers, you have to
setup the receiver source input. For example if you setup the PS3 to
play thru "VCR" input, then you have to make sure the VCR input is
setup to use either optical 1 or optical 2 for sound (whichever one you
have the optical cable plugged in from the PS3).
SOURCE: no sound when ps3 is hooked up to a denon avr 1609
The 1609 only has video on the HDMI. No audio comes through the HDMI cables. Hook up an optical cable between your ps3 and the receiver and you should be good to go.
SOURCE: no sound fom optical input
Do you have your TV hooked up, so you can see the AVR-4800 system menu on its screen (if not, see the manual). You need to go down to the digital input menu item where you associate each component with its input source, whether it is coax, optical 1, optical 2, ..., etc.
SOURCE: no television sound from denon avr-3000
TV has Component input (Green,Red,Blue) connect as follows:
1. Connect Component Video and Audio cables from the Cable box, PS3, DVD or Sat box to thea Component Video and Audio input on the Denon (TV/DBS, DBS,VCR1 VRS2, VDP or DVD).
2. Connect a Component Video cable from the Denon to the TV Component Video input.
3. If you do not have a cable or sat box and have a cable from the wall to the TV you must take an RCA(Red&White) audio out of the TV to an input listed in #1
