How do I replace the left front turn signal bulb on a 2000 Mercedes s500?
SOURCE: replace the front turn signal light bulb
you should have two tongues holding the main headlamp assembly, they are towards the inside of the engine compartement, slide them off upwards and wiggle the assembly and should come off, once off you'll have access to you signal light, hope it helps
SOURCE: Chevrolet Cavilier turn signal bulb
I know what you mean, it is really tough to get to. I just had the guy from autozone put it in for me when I bought it. It got to it quick.
SOURCE: 2000 Accord turn signal problem
either the front or the rear turn signal bulb is blown, that is why the flash frequency is high. replace the bulb and the problem will be solved. best to replace both the front and rear turn signal bulbs. good luck.
SOURCE: left turn signal problem on06' chevy tahoe
check your left light fixture.make sure you have a good contact.sometimes they burnout
